Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Going to build a 383 HSR AFR
Old Oct 22, 2017 | 09:37 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I am going to start collecting parts for my 383 build soon and want to get the right parts. These are what I am thinking... https://www.summitracing.com/parts/c...8/applications
https://www.summitracing.com/parts/sca-1-41829/all I am worried about piston slap with the valves as the pistons are dish shaped.
http://www.airflowresearch.com/195cc...cylinder-head/ Do I want the 65 cc or 75 cc combustion chamber?
As for injectors I was told #36 would be good. https://www.summitracing.com/parts/tfs-89036
As for roller rockers, pushrods, roller lifters, I have no clue what to get. Orr89RocZ I wish you lived in NorCal, I'd have you build my engine.
Last edited by Duane's 91 Z/28; Oct 22, 2017 at 11:04 PM. Reason: forgot injectors
Old Oct 23, 2017 | 07:20 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Going to build a 383 HSR AFR
All looks good. Do the afr heads in 65 cc and get the spring up grade for 75$.
Ls7 lifters if oem block.
Tha setup will run good. Alittle lower compression than i like but good for atreet low oct gas
Old Oct 23, 2017 | 09:55 AM
Car: 1991 red Z/28
I'm going to go to PNP and find a 350 4 bolt block. As for pistons what do you recommend to get better compression? I want to go with forged. And rockers and pushrods?
Old Oct 23, 2017 | 10:20 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If you trust your tuning i would go forged flat top for nearer 11:1 comp but tune on premium pump gas. Might need to keep it richer and lower on timing in spots but it should be doable
If thats a concern run flat tops with the 75 cc head chamber. That be 9.82:1
Or keep dish between 8-12 cc. 12 cc and 65 cc head would be 10.1:1. This is harder to find tho, most dish pistons are 16-28cc which means more like a boost piston.
Old Oct 23, 2017 | 01:10 PM
Car: 1991 red Z/28
Ok I found the LS7 lifters if these are the ones. https://www.summitracing.com/parts/nal-12499225
Thanks for your input. I'll be bugging you more once I get into this sometime next year. Oh by the way my last name is Orr
Old Oct 23, 2017 | 01:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Cool! Those lifters are if you get the oem roller blocks. Any oldschool block wont work
Old Oct 23, 2017 | 02:09 PM
Car: 1991 red Z/28
I am going to get an 87 up 4 bolt block. I'm going to try to find one from '92-'93 years.
