sanding and priming front nose and bumper
Old Jul 28, 2002 | 05:51 PM
theCure's Avatar
Car: Looking
all i basically need to know is what grit paper i should use on the nose and bumper, any suggestions on what kind of sand paper would be good for it and any suggestions on primer?
Old Jul 28, 2002 | 07:16 PM
original's Avatar
If your sanding it down to the urethane. Use 80-100 then go to finer grit as you get closer. I used 340 grit once I got close and I used sandable ppg primer/filler. For a really smooth finish use a wet scotch bright pad.
Old Jul 28, 2002 | 09:25 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
I'm currently rebuilding my nose, and I used a dual action air sander with 200 grit, then I wet sanded with 400 and 600 grit. Make sure you use a primer that is made for plastic pieces... It needs to be flexible so it wont crack up and ruin all your work.
Old Jul 29, 2002 | 05:14 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i totally agree with him
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
mikey8494
Aug 22, 2015 07:57 PM
