Attn: FLYINLOW89
Old Aug 1, 2002 | 03:13 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Attn: FLYINLOW89
First of all, love your car, very sweet! Second, I noticed on your website that you have a Autometer shift light. I was just wondering how that works with your automatic tranny. Does it run off the computers shift points, or no?? Was it hard to install?? I would love to know because I think I am going to get one for my '88 GTA. I had already planned on doing the white face guages and a-pillar guages, but I think the shift light is very sweet! Any help you can give would be great, thanks.
Old Aug 1, 2002 | 03:47 PM
FlyinLow89's Avatar
Car: 1995 Formula/2001 GTP
Engine: 5.7 LT1/3.8 Supercharged
You gotta buy an RPM activated module, which you plug the shift light into. Then wire up the module with power, ground and one wire to your coil's positive. The module is like $60 american. To set the different shift points, there are different RPM pills you pop into the module. its pretty simple.
Old Aug 1, 2002 | 03:55 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
I'd also check out:
http://harlan.sketchy.net/
He makes a GREAT shiftlight, that you don't have to worry about pills, just dip switches programable in 100 RPM increments...
Attached Thumbnails Attn: FLYINLOW89-shiftlight_on_small.jpg
Old Aug 1, 2002 | 09:40 PM
speed88's Avatar
Engine: 383
Attn: FLYINLOW89
Thanks for the help Flyin, I appreciate it! One more question though. By installing the RPM module, are you manually changing when the car shifts?? In other words are you changing the computers shift points?? Thanks.
Old Aug 2, 2002 | 04:50 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Originally posted by BumpaD82
I'd also check out:
Those kind rock!
Old Aug 3, 2002 | 06:47 PM
FlyinLow89's Avatar
Re: Attn: FLYINLOW89
No, not at all. The module has nothing to do with the tranny. It simply gets triggered by the RPM. I manually shift.
85maroz28
Oct 6, 2006 06:27 PM
85maroz28
May 8, 2006 08:42 AM
Demon355
Car Audio
Mar 9, 2006 01:57 PM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
90TA
Jan 20, 2003 09:05 PM
