245 x 60 15's front and back?
Old Aug 9, 2002 | 09:20 AM
1987fbd's Avatar
Does anyone have this set up? I have them on the rear only and want to put them on the fron also but will I get fender rub in corners? I wanted to go 50's but lack of money and great deal on 60 series. Thanks for the replies in advance!:hail:
Old Aug 9, 2002 | 12:28 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
If it helps ya I got 255/50/16 on all 4 corners of my sport coupe, and they rub in the front when I cut it all the way. Eventually I'll go thinner up front.
Old Aug 9, 2002 | 02:20 PM
1987fbd's Avatar
Well that does help me to not buy 255's...lol.
Sounds like I might be ok with 245's on the front.
I don't like the idea of going with two different sizes on my car.
Feels like it handles poorly that way, maybe just my imagination. Thanks for the info!
Old Aug 9, 2002 | 02:31 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I have 245/50/zr16's all around.
Mine rub in the front.
Old Aug 9, 2002 | 02:52 PM
1987fbd's Avatar
They do rub? Damn i guess 60's will definatly rub then.
Maybe not though cause I have 15" wheels
Old Aug 9, 2002 | 02:56 PM
86IROCZ's Avatar
Same set up, mine do not rub though! But I also just rebuilt my front suspension. I think that this is the stock size for an IROC anyway.
Old Aug 9, 2002 | 03:32 PM
MG86TA's Avatar
I have 245/50/16zr's and they don't rub.. well, they will rub for the first like week, but then it will wear down the place where it rubs on and u will never have the problem again.. dont worry.. its just plastic that wears down, nothing serious
Old Aug 9, 2002 | 03:38 PM
KZad's Avatar
Exactly .... I never see or feel them rubbing, however, the plastic wheel well has rub marks. Maybe its from the previous owner trying to put monster tires up front, I dont know.
245/50/r16's were there origional size for my car (88 Formula) so I dont see why they should rub.
You should be fine with 245's
z
Old Aug 10, 2002 | 05:33 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
I got 235/60/15 in front..they rub when I turn the wheel all the way. I have 255/60/15 in back not even close to rubbing.
Old Aug 10, 2002 | 06:08 PM
83T/A_Dave's Avatar
245/60/R15
I have 245/60/R15's all around on my 83T/A and I only get rubbing when at steering extremes (ie: backing up with steering cranked). So if you want no rubbing I would suggest not going with them, all though you do get a cool look having the same all around.
I may also have a higher ratio T/A steering box which would make the comparison off a bit if you have a sport coupe.
hope this helps.
your neglecting the fact that he asked about 15 inch tires and not 16 inch.
Old Aug 10, 2002 | 10:57 PM
Snowdog 91 Formula's Avatar
BFG's 245/60/15's all around no rubbing whatsoever.
Old Aug 10, 2002 | 11:15 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
255/15/60 in the back - no rubbing
245/ 15/60 in the front - only rubbed for a week or so. the handling from the 2 different sizes is great. You will not be able to tell anything. And i just got my entire front suspension rebuilt with all new parts. I love the set up and it gives me that raked look without being too seventiesh, if you know what I mean.
Old Aug 11, 2002 | 12:26 PM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
i've run 245/60 x 15 for 60,000 miles no rubs at all. Glad to see the 50 's fit. that's my next choice
Old Aug 11, 2002 | 04:55 PM
TransAm87's Avatar
i have the 245/60/15 up frong, i had rub, had to cut some of fender rubber protector out, no big deal, had to buy b/c lack of money, tre 235/60
Old Aug 13, 2002 | 02:58 PM
1987fbd's Avatar
Wow, thanks everyone for all the replies. I knew i could count on the third gen people here.:hail:
Well I am on my way to pick up the other two tires after work so I have a matching set of 245/60/15.
Thanks again!!
Old Aug 13, 2002 | 03:06 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
so 245's fit the original firebird rims? cool, then i know what i'll get to replace my 215's
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
db057
Aug 22, 2015 08:17 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
