What size tires to go with??
Old Aug 23, 2002 | 07:41 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
if i get 15" rims what shohuld i go with??
and if i get 16s i'm gonna put on 245/50/16 on the back but what for the front??
any suggestions....
Old Aug 23, 2002 | 11:11 PM
taturbo's Avatar
Car: 3 3rd Gen F-bodies and 7 others
Engine: 305 CFI, 350 TPI & 3.8 Turbo V-6
Transmission: all automatics (stock)
On the 15" rims go with a P235/60R15 as long as the rim is around 7 to 8" wide. Will look good and handle a bit better than stock P215/65R15.
For 16" go with the P245/50R16's all around. Then you can rotate them. If you want a shorter sidewall in front, then use a P245/45R16, while maintaining the same width.
Old Sep 27, 2002 | 09:05 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I got
215 / 65R / 15 up front
255 / 60 / 15 in the rear.
Old Sep 27, 2002 | 11:33 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I had 245/45/16's on the front of my formula and the tire looked a little small for the rim. In back I had 255/50/16's.
I think when i replace the rubber on my gta i'll go 245/50/16 front and 255/50/16 rear.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
