4TH gen wheels
Old Aug 26, 2002 | 02:28 PM
mat89RS's Avatar
4TH gen wheels
I now have these American Racing 17 X 9.5 rims, I know I need the wheel adapters.
I have a great opportunity, I can get 4 adapters-spacers for around 50$. (not the cheap stuff, good ones)
The thing is , it's 2" thick x 4 adapters.
Will the rear tires rub in the fender ??? I will be running 275 ZR 40
Old Aug 27, 2002 | 02:22 AM
jawzforlife1's Avatar
It all depends on the backspacing o the wheels. check out this sight.
http://www.skulte.com/adapterfaq.html
it will tell you how to messure backspacing, once you know that messurement, e-mial the skulte guys and they will tell you the size you need for those wheels.
Old Aug 27, 2002 | 11:10 AM
mat89RS's Avatar
these have the same backspacing as 4th gen wheels. I'm just owndering if it will fit with 2'' spacers.
Old Aug 27, 2002 | 11:12 AM
I think it is 2" in the rear, and 2.25" in the front, if the offset is 38mm (the small offset). My wheels have 56mm (large offset) so I needed 2.5" in the front.
You will need large adaptors in the front than in the rear.
Hope that helps.
Old Aug 27, 2002 | 02:18 PM
mat89RS's Avatar
Omega
Oct 1, 2015 02:20 PM
cam-mike
Aug 24, 2015 07:23 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
