stock radio is locked
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
i have a stock radio out of a gta and i want to see if it work but when i plug it in it says lock. does anyone know how to unlock it?
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
push and hold down the 'mute' button on the steering wheel.
this will unlock the radio.
high tech security, eh?
-Schultzy
EDIT: If the radio is not in a GTA with the wheel or you do not have the steering wheel controls hooked up... good luck! I don't know that you can use it.
-Schultzy
Car: 1989 GTA
Originally posted by Ward
it is not in the car anymore is there any other way to unlock it other than the wheel.
I think that this was the point in the design i.e. if someone steals the deck out of the car it will be useless to them anyway. That being said, I would think that there would be a way to 'fool' the deck but I do not personally have the technical knowledge of the system to be of any help to you.
Anyone else out there that can help ?
-Schultzy
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Uhh this maybe a long shot but try to cut the power to your car from the fuse because i read something about the SES light checking and resteting and if you disconnect the battery you could have to put a 4 digit code or something .. hey it may work...
what year is the radio from?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I have the same Question ???????
I have the same question as Ward,......
I currently have 2 of these units..... one displays "LOC" when plugged in & the other plays normally in any car I plug it into.
To UNLOCK the code I have been instructed to use the "MUTE" button on the steering wheel while the system was installed in a Bonneville or a GTA. But I have also been informed by the same sources that once you unplug the radio again - the dam "LOC" is re-activated.......
SO ---->
Once the steering wheel control radio is "UNLOCKED" by pressing the MUTE button of the streering wheel controls ---- How in the Hell do you obtain the lock CODE !!??!?!? Once the lock CODE is discovered,............ How do you disable it and bypass the security feature ???
Like I said - I know it can be done because I have another radio that is the same exact type of radio that is unlocked & in perfect working order !!!!
ANYONE HELP !!!!
SO ---->
ANYONE HELP !!!!
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
