Pontiac Trans Am 5.7 TPI at ebay for a G.
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Only a G and you get all of that? Well I figure if We give it 3 dayz the price will be at 6,000.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1867486013
Car: 99 Formula
Axle/Gears: 342
I wouldn't pay $6k for that. The wheels are hideous.
No motor pics, what kind of 350 is it, better get the block # off of it first.
Car: 00 TA, 91 Formula, 89 RS
Yes. Yes they are. But I wouldn't not buy a car because of the wheels on it. The wheels come off, remember?
The engine has 168k on it. No way is that car worth 6k, unless it had a 700 bhp 350, then yeah, otherwise, ah no.
A friend of mine bought this car back in 1994 with a blown motor. We put a new 350 motor in it.
um, no thanks. Is that thing about the transmission correct? Does that smell fishy to anyone else?
The trans has low miles, it also has a shift kit installed. Since the trans was put in the speedometer is not accurate. It puts more miles on the car than are really on it. The car probaly has like 100,000 real miles but the odometer says 168,000 so thats what I am selling it as
Yes thats right, if the gears are off of whatever is stock, it will roll the speedo faster...
I wouldnt buy it...well, maybe for like $2500 or so, and a head job
Car: 99 Formula
Axle/Gears: 342
Originally posted by KlayBuRn
good plan, i agree
good plan, i agree
Car: 99 Formula
Axle/Gears: 342
No no no...not shift kits, improper GEARING is what makes it roll faster or maybe slower...
well what he said,
"The trans has low miles, it also has a shift kit installed. Since the trans was put in the speedometer is not accurate. It puts more miles on the car than are really on it. The car probaly has like 100,000 real miles but the odometer says 168,000 so thats what I am selling it as
Yes thats right, if the gears are off of whatever is stock, it will roll the speedo faster... "
Has nothing to do with gears. In fact, in the whole description, he doesnt mention the rear end at all.
I already knew changing the gears would change the odometer.
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Dayum that's alot of friggin' rust! (did anyone see the door??) I see just another $500-$700 range parts car.
The thing with the 350 is that if it is not the original motor, who knows what is in there. Casting numbers don't mean squat either, sure you can verify CID and block type, but that says nothing for the internals. Besides, I bet my lunch that the car is still running the 305 cid injectors/ECM setup.
I'llrocya
Feb 2, 2016 11:43 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
