just got out of the hospital
early this afternoon i was in what would have been a minor fender bend but ended up not being. i was rear ended at a red light by some lady following to close, the car is only slightly damaged. I would have been fine except ofr the fact that my seat belt failed to locked and i smashed my head against the top of th car and my whole left side of my body against the steering. i am ok just some minor injuries and bruising but my question is why did my seat belt fail was it part of the recall?
I'm convinced that the air bags on our cars DON'T work.........
Good luck with the recovery......also there WAS a seat belt recall, but try the history boards and you will find the info you need....
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Take your car to the nearest GM dealer, if it has already (or doesn't need) the seat belt recall fix they can tell you. If you do need it, then they'll do it for free.
I can pull as quick and hard as I want on my seat belts it doesn't do a damn thing, I remember a post from a very long time ago...asking if anyones actually worked, almost everyone said no. (I'm talking like two years ago.)
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Glad to hear you're doing alright man!
I asked a similar question a while back regarding Chevys in general, because I've owned 4 different Chevys (75 Camaro, 86 Camaro, 89 Pickup & 95 Tahoe) and NONE of them locked by pulling the belt. I was told that these belts are not built to Lock on hard pulls like a lot of belts from other manufacturers. There is instead a mechanism in the "rollers" with a weight that will slide forward and lock the roller/belt when the vehicle crashes or in other ways make a sudden stop.
If this is correct, I don't know. But it would be kinda strange that all 4 cars from a 20 year period, had faulty seatbelts - so I tend to believe that this might be correct. Anyone know?
Ken
Ken
Car: 91 Red Sled
Ken is right. If you ever take apart the seat belt you'd see the weight. Drive at 40mph and slam on the brakes, you won't go anywhere! I think it's a good design because my Dad's 95 burban is a PITA and so are most newer cars. Now the seat itself not staying back is a whole nother story. THAT is a problem with most thirdgens. The latch will break and the seat will just swing up without ever again needing to use the release at the base!
Car: '82 Z28
Another reason why I'm putting in a cage with a 5 point harness.... however, I think my belts do lock with a hard tug.
i notice the car is ticking now for some reason, it sounds like its coming from the engne and now there is a real heavy fuel smell, ne ideas? also its hard to shut my doors now could this have been caused by the accident
Car: 91 Red Sled
Car: 1989 Firebird
Engine: 5.7 LS1
Well it probably split the top of the tank where the filler neck goes into the tank. If the doors are hard to shut than it tweaked the frame, it needs pulled probably, and you will have to run sub frames or if you have them now re do them. The insurance may end up totaling your car if it messed up the frame, tank, body and engine. One of the problems on our cars is the front brakes work so much better than the rear, so all the force from the hit was distributed from the rear bumper to the front wheels.
sorry man, thats frame damage. I'd have it towed to a frame shop and let them take a look at it, and give you an estimate on how much to pull it. probably going to be more than you want to spend
frame damage can be caused from such a extremely minor accident? that ****ing sucks, but hey new third gen here i come! wil they take the car if they totalled it? cause i would still like to resto it and give it to my lil sis. so how much does an 88 sc with 305 w/ 130,xxx miles go for neways? oh dont forget plenty of rust? i better get a little something out of it!
So that's why my seatbelt kept choking me when I was auto-xing.. I thought it was FUBAR... my seatbelt never locks, but when I was auto xing it would trap me up against the seet so tight I couldn't see properly. It was frustrating as hell.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Ken
Ken
IrocZ85
Jun 6, 2006 02:21 AM
Barry85Iroc
South Central Region
Nov 18, 2003 09:14 PM
easySPEEDcamaro
20
Sep 16, 2002 11:01 PM
