3rd. Gen Wheel Sizes !
Old Nov 19, 2002 | 08:38 AM
Archs89's Avatar
I had a friend call me the other night and he's wanting information on wheel sizes for a 86. His son has caught the local bug and wants to buy 20 " wheels. He wants to get 18 " wheels instead. So if any of you have 18 " or 20 " wheel please reply , let know your type of wheel , what back spacing you are using on front and rear wheels and what size tires you are using with the wheels.
Thanks ,
Arch
Old Nov 19, 2002 | 01:24 PM
MdFormula350's Avatar
try asking this question in the Appearance and Detailing board you might get more responses!
Old Nov 19, 2002 | 05:48 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
there is a kid where i work at with 20 x 8 wire spoke wheels on his v6. but the rear tires are being cut up by the fenderlip.
Old Nov 20, 2002 | 01:23 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
This is the appearance and detailing board.
Old Nov 20, 2002 | 01:21 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Thirdgen's have a rough ride stock.... I can only imagine how uncomfortable it would be with 18'' wheels (no tire sidewall to absorb shock).
Old Nov 20, 2002 | 02:09 PM
CrazyHawaiian's Avatar
Car: too many ...
Yes a few guys run 18's. I have a set of 18's myself but they are not mounted yet. I have seen pix of a 3rd gen on 20's but he had to leave the suspension stock. The backspacing and stuff will depend on how wide the wheels are. Its just the same as any other size wheel. For 18's you should run 40 series tires. For 20's I think you hav to run 35 (ouch!)
Old Nov 20, 2002 | 03:24 PM
MG86TA's Avatar
Plus the 20's would take a wee bit out of your 1/4 times... Ill just stick with the 16's and 17's
Old Jan 2, 2003 | 01:01 AM
Kandied91z's Avatar
ever find your answer?
anyone know the average weight difference to go up in size on a standard make rim like a 17x9.5 to a 18x9.5?
Old Jan 2, 2003 | 04:39 AM
Car: too many ...
It would depend on the material of the wheel. I'm sure if you emailed the wheel manufacturers they would give you weight specs for each size. Thats what I did.
Old Jan 2, 2003 | 02:57 PM
Kandied91z's Avatar
well i asked on the z06 just for reference and it's just a hair over 1lb to go from 17-18...?
doesn't seem right though?
Old Jan 2, 2003 | 03:12 PM
85_ZED28's Avatar
Car: '85 Z28
1lb seems like alot for 1 inch
PS have you decided in a set of rims yet Kandied?
Old Jan 2, 2003 | 06:44 PM
Kandied91z's Avatar
not yet.........soon though, very soon!
Old Jan 3, 2003 | 06:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the actualy weight shouldn't matter as much as the distrubution of the wieght with the tire MOUNTED. because the wheels are rotating you could have a wheel tire combo weight a couple of pounds more, but if all the wieght is close to the center it will be easier to turn than a wheel weighing less, whose wheight is all distributed towards the outside.
Old Jan 3, 2003 | 11:48 AM
Kandied91z's Avatar
so how would you determine that? off design alone?
BlueIroc-Z
Jun 9, 2019 03:22 AM
toronto formula
Nov 10, 2015 06:17 AM
Omega
Oct 1, 2015 02:20 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
knight72
Aug 10, 2015 09:32 PM
