Polishing results..........
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Wet sanded to 2000 grit, polished with a drill buffer with mothers aluminum polish. Results =
Today I took it to a real buffing wheel with white rouge. Results =
<=A Happy camper. To all those who told me to use white rouge :hail: :hail: :hail: :hail:
Cannot wait to do the whole intake.
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks guys
Yes sir
Originally posted by 82firebird
wow! very nice! Is your buffing wheel one of those Eastwood products?
Yes sir
Car: 85 Camaro SC
Engine: V6
Looks great
To bad hand polishing cant get inbetween the raised lines. 6" polishing wheels on bench grinders are the only way to go. Heres some of my old work I did for Bimma86.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Sweet. I can't wait to finish my rims and my fuel rails and fins on my LT1 intake
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
DAMN! 85sportcoupe, you rock on the polishing!
Car: 1989 IROC-Z
Engine: 383 stroker
Originally posted by Black_Widdow
Where can I get some White Rouge? I cant seem to find any
Car: 85 Camaro SC
Engine: V6
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
Originally posted by 85SportCoupeto89RS
Looks great
Looks great
i want to polish my TPI intake, whats your secret to your polishing?
Car: 85 Camaro SC
Engine: V6
Now I didnt just start doing this one day and was awesome at it. I've spent almost a year in the Street & Performance polishing shop where I learned every thing. Most things you learn from polishing cant be expressed with words reall good but with practice and trial and error. Hehe thats basically how I did learn to polish. You do plan on spending some cash right? No not to pay me to tell you how to polish. LOL The materials you will need to get can cost some money: Bench grinder, da sander, die grinder, and materials that you will need.
LOL, polishing is a lost art but with time and practice you can come up with some awesome techniques and time saveings procedures. Go to http://www.caswellplating.com for most of the supplies and http://www.hobbyplating.com/ also go to get a die grinder http://www.handsontools.com/store/l...category_id=201
This is a little long but it basically gives you the nessicary information to get started and what supplies you need.
Never mix different greases on the same wheel. Bench grinders will last a whole lot longer if you keep both shafts balanced "have a 6" polishing wheel on each shaft". I've always polished using the sisal wheels with Tripoli grease to get into tight spots and to go over my da sanding marks. I usually do that until all da marks are gone and the part has a dull shine to it. Then I would use a 6" sprial sewn cloth wheel with white color compound. Do that until you get a good shine. The white compound is good for getting the shine into the aluminum and it can be used with the 6 loose buff for final buffing and getting the best shine from your parts. And that save on some cash instead of having to buy 3 different polishing compounds. http://www.hobbyplating.com/wheel.htm this is where I sometimes get my polishing compounds from. The prices are good and the bars last for some time with care http://www.bright-works.com/store/html/comp.html. You can also get some polishing compounds here too.I get polishing wheels from
http://www.bright-works.com/store/html/buff.html
I like the prices for their wheels, I get the loose buff and the spirals sewn wheels, and the sisal wheels. You can also get sisal wheels from http://www.tptools.com/prod_list_di...ing%2FDetailing I like this sites sisal wheels better than the BrightWorks.
I get the sanding drums from Brightworks. You need to get arbors for the sanding rolls to attach to. I always get the box of 100 rolls and the grits I always get are 120, and 320. http://www.bright-works.com/store/html/rolls.html
http://www.handsontools.com/store/l...category_id=201 They have a variety of diegrinders for the sanding rolls. I use the Astro 1/4" Drive Extended Shaft Die Grinder for 70 dollars. If it ever siezes up I just buy another.
And with everything else in life it just takes patience and practice to get good at something, just because the results you were hoping to get dont show up in the first try dont get discouraged. Some aluminum has "gas" tiny air bubbles in the aluminum. Theres absolutely nothing you can do to get rid of this. You will know when you see it. Good luck,
Michael O
Michael O
your polishing looks great, I have polished my plenum and the dist cover, I have started using the black emery, it doesnt look to bad, shinny but it has what looks like sanding marks from the buffing wheel. This is my first time doing this and im have fun doing it, provided everything turns out well I hope to polish all my aluminum parts
How much polishing compound am I supposed to be using on the wheel? and are you supposed to wash the parts after polishing with one compound? I tried to use the tripolli coumpound with a new wheel after I did the black emery and it turned my buffing wheels black and the finish got really dull, Im not sure if im doing any of this right, but I have lots of time to get the shinny finish im looking for right.
How much polishing compound am I supposed to be using on the wheel? and are you supposed to wash the parts after polishing with one compound? I tried to use the tripolli coumpound with a new wheel after I did the black emery and it turned my buffing wheels black and the finish got really dull, Im not sure if im doing any of this right, but I have lots of time to get the shinny finish im looking for right. Supreme Member
Car: 85 Camaro SC
Engine: V6
What kind of wheel did you use the tripoli on? Sisal wheel, sewn cotton wheel,or loose buff wheel?
I think its a sewn buffing wheel. Its a 2 1/2" buffing wheel with a 1/4 inch shank, it was the only one i could find to be used on a drill. I found this trucking store that sold a 6" wheels for a grinder but it seemed to be a little over kill for the size of my project, the sales guy was telling me that they use the 6" inch on cemi gas tanks and large parts like that.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
85SportCoupeto89RS, I will have to "contract" you out this spring on my intake, and possibly a few other components on this new engine.
You use to work at s&p, here in north little rock?? You may be closer then I thought before!!!
Car: 85 Camaro SC
Engine: V6
IROC_5796, the sewn cotton wheel will not work properly with the black grease its too abrasive of a compound to make aluminum shine. Normally those compounds are used on a sisal wheel. I would use your white grease on your sewn cotton, and loose bufifing wheel. Its much cheaper to use the with grease on both sewn,loose wheels. You'll get the same results even if you use the tripoli with the sewn cotton wheel. I only use the 6" wheels on a bench grinder, a da sander with 180,320 grit, a die grinder with 120,400 grit.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I have been using Mother Aluminum Polish to polish my aluminum....looks pretty good....but..the White Rouge looks a lil better
.....where do you guys get this stuff? I heard that it's actually a bar.....how do you apply it? Thanks Fellas
.....where do you guys get this stuff? I heard that it's actually a bar.....how do you apply it? Thanks Fellas Last edited by Sickness91Z28; Jan 28, 2003 at 05:37 PM.
Car: 85 Camaro SC
Engine: V6
Do you polish by hand 84customZ28? Yep their bars
To use the white rouge you need the polishing wheels,bench grinder, and the polishing compounds. Be prepared to spend some cash www.caswellplating.com I still have to build my polishing shop before I can buy all the stuff I need to get up and polishing again. Freakin uncooperative weather.
To use the white rouge you need the polishing wheels,bench grinder, and the polishing compounds. Be prepared to spend some cash www.caswellplating.com I still have to build my polishing shop before I can buy all the stuff I need to get up and polishing again. Freakin uncooperative weather. Last edited by 85SportCoupeto89RS; Jan 28, 2003 at 06:02 PM.
Engine: 5.7
Well....for small pieces, yes, I polsih by hand...but when I do my plenum..I'm going to use a buffing wheel. But..I'm keeping the Plenum on my car.....so..I guess white rouge is out of the question? Or...would I be able to use it on a buffing wheel?? (like a polisher...high speed)
Car: 85 Camaro SC
Engine: V6
Your going to sand, and then polish with a hand drill? You can do it like that with a cotton spiral sewn buffing wheel and the white grease, and follow it up with a loose buff with the white grease. I do strongly suggest you take off your plenum when you polish it, you're back is going to kill you once your done. Not to mention the possible mess you'll have under the hood.
Engine: 5.7
I'm not going to be using a drill buffer......I'm using a polishing buffer....like used to buff paint....I would take the plenum off....but..I'm not much of a mechanic..and I'm not sure if I could get it back together....pretty sad huh..lol..
Car: 85 Camaro SC
Engine: V6
OIC, lol. I would buy your self a back brace. I used a dewalt buffer at work before. I polished 9" rear end pumpkin, thank G0D I didnt have to hold that up to a polishing wheel but the other way around.
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Looks great, that was a good job! I am LOL with the weather and time graphics that's live with your link, how did you do that?? Andy
Car: 1988 IROC-Z
Engine: 427 SBC
Originally posted by KCobain147
Hey joe..where did u get your tools to do that..and how much did they set ya back?..i was thinkin bout doin my rims this summer
Hey whats up?
I used my dads bench grinder to power the wheel so that saved me some money
I got my wheels here:
http://www.eastwoodco.com/
Buff Wheel 8 Inch Spiral (For tripoli)
item no: 13033
Price: $ 7.99
Buff Wheel 8 Inch Loose (For Rouge)
item no: 13044
Price: $ 7.99
And I got my compounds here:
http://www.harborfreight.com/cpi/cta...temnumber=9736
bigjay89gta
Oct 15, 2015 08:04 AM
didn't attach the pic.
