chromed t-stat housing?????
Old Feb 1, 2003 | 06:27 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
ive sent a replacement one to pauls chrome......and they want well over a hundred bucks to chrome it. Sorry but i think that is way overpriced. Does anyone now where i can find one already chromed? I see them all the time on other cars...just a standard thermostat housing that sits on the intake manifold. Some other people might call it a "gooseneck".
Old Feb 1, 2003 | 06:43 PM
Cuno's Avatar
Here are some from Summit http://store.summitracing.com/
http://store.summitracing.com/partde...57#largerimage
http://store.summitracing.com/global...um-g3801_m.jpg
They are under engine dress up
Old Feb 1, 2003 | 07:16 PM
TorchRay's Avatar
Car: 89 WS6 Formula
will some of those work though? Mine looks kinda the same as a chevy one....only the neck on it is farther out. the metal hose part comes out of the housing, takes a sharp 90' curve then straight out bout 4 to 4&1/2 inches.
Old Feb 1, 2003 | 07:44 PM
Cuno's Avatar
hmmm...not sure. Not sure. Maybe you could get a hose at a local auto shop that would work with a different housing. I would assume that it will bolt up to your engine. Not sure if there would be any problem there or not.
Old Feb 2, 2003 | 06:17 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
if its aluminum, why not just polish it?
Old Feb 3, 2003 | 07:50 AM
TorchRay's Avatar
Car: 89 WS6 Formula
ill have to look into that....im not sure if its alluminum or not. Any other info on where i can find one??
Old Feb 3, 2003 | 10:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's aluminum, and they look GREAT when they're polished.
This is the best pic I've got that shows my polished water neck:
Old Feb 3, 2003 | 11:03 AM
Jza's Avatar
Jza
Yes, your stock housing is aluminum, so you can polish it. The procedure is the same as when you polished your interior plastic pieces. Eastwood has a $20 kit that has the compounds and wheels that you'd need to buff brass and aluminum and it'll last you years. I sanded mine in a couple hours at work, then finished it on the wheel at home.
Also, Summit has some polished aluminum swivel waternecks but they may not work with a TPI motor. They run about $25.
Chiknhawk
Exterior Parts Wanted
Oct 15, 2015 09:51 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
