Stupid rim polishing, *** help me
Old Mar 19, 2003 | 12:40 PM
  #51
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i did this with 600wet and 1500 wet and before those i used a polishing disk thing on a air tool to get off the old paint and whatnot. then i polished with mothers alumin polish. did that in about 2 hours becuz i kept on being inturupted and if u look at that dirty ugly brown color just to the top of the plentum thats what it looked like before this.
Old Mar 19, 2003 | 03:39 PM
  #52
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
CustomX: which way did u polish?? the up to 400 then use that tripoli, emery way or use the 120 up to 1500 grit way?
Old Mar 19, 2003 | 03:45 PM
  #53
A88GTANotchback's Avatar
Do i need to use the stripper stuff in my rims still. or willthe sanding take care of that?
Old Mar 19, 2003 | 04:31 PM
  #54
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
ok, well i went to that eastwood companys web site.. and all i could find was that tripoli and emery stuff in a tube... which is great and all if i had a flat spot, but since im also doing my bikes frame/forks which has alot of round spots.. i dont see how that is going to work.. so i guess ill stick to my good old 9 different kinds of sand paper.
Old Mar 20, 2003 | 01:08 AM
  #55
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
utp 400 then compunds.
That rim is ok, but it will be redone since i learned alot ffrom it. You need to thouroughly get rid of the machine ridges with the 100 then you really need to dig in with the 320 and do alot of 400. the areas i did more 400 in seems to loook a bijillion times better and my next rimm will turn out 3-4 times shinier then the one i posted. that was my first attrempt.
Old Mar 20, 2003 | 03:24 AM
  #56
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
ok..
well what i did is just sand liek crazy with the 180 grit and got out all the little pits, then with teh 220 and 320 i jsut sanded till all the scratched were out.. then wet sandign was easy. but for some reason when i was doing my forks on my bike, they came out damn near perfect, and im only at 1000 grit.. where as the frame is at 1500 grit.. but seems alot more cloudy.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
