QwkTrip has a hood???
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Stock? I thought you needed a cowl to fit that under there
Looks good though.. AWESOME sleeper!
Car: '89 Firebird
Engine: 7.0L
The hood is on for storage purposes. The supercharger pulley doesn't clear the hood because of the slope on the nose. If it was a Camaro it would all fit.
I have an extended oil sump and I'm going to put on a normal oil pan and gain 2-inches of ground clearance. Then I'm going to drop my crossmember 2-inches and the pulley will clear. At best I will have to use a small 2-inch cowl from Harwood to clear an air filter. Still, that's not too suggestive of what's under the hood.
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Ah.. very nice...
I couldn't believe it at first, I thought it wouldn't fit with a hood..
I was thinking.. All that time trying to decide on a hood, and he gets a stock one
Storage purposes are good I say. you could cut a hole in the hood to fit the pully
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
I think this is the first picture with a hood since I've been a member here.
