Deleting "IROC-Z" Door Decals..
Subscribe
Mar 29, 2003 | 07:44 PM
I'd like to remove the "IROC-Z" door decals from my car..
Wondering how I should go about doing it..
Any chemical remover I should use? Razor blade? Tool?
I want to make sure I don't damage the paint behind it..
A friend took off the GFX stripes a few months ago, and used a powered eraser tool... it worked, but it was messy and we had to be really careful not to burn the paint.. so I'm lookin for an easier solution..
-LJ
Reply 0
Mar 29, 2003 | 07:51 PM
i don't know about any of the other stuff, but if you don't want to hurt the paint, definately don't use a razor.
Reply 0
Mar 29, 2003 | 07:55 PM
try a heat gun or a blow dryer to heat up the adhesive that the factory used and it should come off with the heat gun and a plastic like knife thingy.
Reply 0
Mar 29, 2003 | 08:06 PM
Eraser. You can pic them up at autobody shops. The go on the end of a drill...and are GREAT for removing decals and pin stripes. There run about 15 bucks. Good Luck with what ever way you choose
Reply 0
Mar 29, 2003 | 08:14 PM
Quote:
Yeah, that's what my friend used to remove my GFX stripes..
Worked really good, but it was messy.. and we had to be careful not to push too hard, cuz those drills can leave marks..
Sounds like it's still the best way to do it
-LJ
Reply 0
Mar 29, 2003 | 08:21 PM
-LJ
Usuallly when removing any kind of decals or pinstripes...it's a messy job..whether a heat gun..or an eraser. I always go over the area with some compund to get some of the "mars" out if any were left behind. The reason I like the eraser...is because if your not careful with a heat gun..the paint could get to hot and melt off..and with a razor blade...you could leave some pretty nasty scratches....even down to bate metal. The Eraser is pretty safe...just take your time and it should work fine. If your not able to get an eraser..I would try a heat gun.....it's safe...just be sure to take your time with that as well.
Reply 0
Mar 29, 2003 | 09:28 PM
I used 3M General Purpose Adhesive cleaner. It worked fine.
The part# is 051135-08984
Reply 0
Mar 30, 2003 | 05:14 PM
It just came right off?
Did it eat the decal or did u have to scrape it off with something?
-LJ
Reply 0
Mar 31, 2003 | 11:38 AM
you gotta scrap it off with something....it takes awhile but it turns out fine. atleast on my car it did.
Reply 0
Subscribe
