LED's
Old Apr 1, 2003 | 01:55 AM
Kevs86TA's Avatar
Car: 86 Trans AM
LED's
I was wondering if anybody has installed led's in the interior instead of using neons? If not, what would i need in order to do this. I was thinking of blue led's under the dash and under the front and back of the seats.
Old Apr 1, 2003 | 11:22 PM
Kevs86TA's Avatar
Car: 86 Trans AM
Um, nobody knows? HITHERE did HITHERE search and did come up with what HITHERE was looking for.
Old Apr 2, 2003 | 09:37 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
i am planning on doing this in one of my cars.
first off. you need an led of 2500 light intensity or higher. then you need to figure out the resitors that you would need to keep the voltage down. also, you need a high intensity, wide dispertion pattern, so it spreads the light evenly, instead of being like a spot light like a third brake light.
good luck.
thanks
anthony
Old Apr 3, 2003 | 03:04 AM
Kevs86TA's Avatar
Car: 86 Trans AM
Sounds like alot of work.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
