Polishing Rims, Let me see them
Car: '91 Z-28
About the center caps one of the caps had sever corrosion all the way through the aluminum skin actually so i did some quick bondo work and then painted them. I didnt have the time or money to order a new cap and polish them although i know they would have looked nice that way as well.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
what kind of paint did you use to paint those red ones? they look SWwwweeeeeeeeeettttttt!
Car: '91 Z-28
The paint that I used was dupli-color touch up paint in the 5 oz. spray can. It was a tough color match though because they don't make the shade with the original color code to match up with my car. So what happened was I tried a color called "Medium Garnet Metalic" first but it had too much of a purple tint to it so then I went over it with a color with a chrysler color code called "Garnet Metallic" and that is how it came out. I also hit the painted areas with a clear coat for shine and protection. It is almost an identical match to the original body color. You have to get really close and stare at them for a while to even start to see a difference. Of course before i painted them i did spray a coat or grey primer on the rims. Thanks for the compliment though.
Car: 1998 Camaro Z28
Engine: 6.0L
sorry, this is the only pic i have of mine right now. but they didnt turn out too bad. a couple tiny spots had just too much pitting w/o making big dips in the aluminum, but you cant see them unless youre up really close.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
bigjay89gta
Oct 15, 2015 08:04 AM
