help with springs
Old Apr 13, 2003 | 09:17 AM
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
help with springs
i spent over an hour last night looking at posts about lowering and i am more confused that i was when i started.
i seen alot of ppl have used panhard bars ect. is this a must???
mu suspension is in prefect shape now bur my main consern is of corse the lowerd stance and most important the quality of ride.
want it to be the same or better not in the least worse.
when i posted a while ago the prokit was the way to go.but when i called summet they gave me a lot of choices intrax 2 inch and the sportline 2 inch...i would love the 2 inch ones but what will happen if i do not use the pan bar????
any help would great so i can place the order on one of these kits
http://community.webshots.com/user/paulstoy71
http://community.webshots.com/user/paulstoy86
Old Apr 13, 2003 | 09:54 AM
llvll4l2c91350's Avatar
if you plan on lowering it 2" then it is highly recommended that you also get adjustable panhard rod, LCA's and LCA brackets. mine only dropped 1" but i do plan on gettin this stuff. the rear end will shift and you'll lose traction once you lower it. i went with the eibach prokit. a lot of people here are also running eibach sportline springs which can drop a car as much as 2".
Old Apr 13, 2003 | 12:02 PM
MdFormula350's Avatar
yeah i get the prokit and i bought an adjustable panhard bar from spohn, cant wait to install the stuff..
hey llvll4l2c91350 i cant send return private messages because your box is filled..
clear out all inbox messages you dont need, also delete the sent messages and message tracking ones.
hey get aol aim account, my name is formula350md talk to me on their
Old Apr 13, 2003 | 12:06 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
The best place for this post would be the suspension board.....
The adj panahrd is meant to recenter the rear end. since after dropping, some/most cars rear end will shift to onse die an inch or 2. you can actually measure this, then adjust the panhard to bring the rear end back in center.
Old Apr 13, 2003 | 12:08 PM
gonna do that now...
Old Apr 13, 2003 | 01:03 PM
Car: 86 trans am
ok thanks can it be moved by a moderator for me???????
if not i will re post
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
