help with polishing runners
Old Apr 21, 2003 | 01:14 PM
figge's Avatar
Hello,
I did just polished my plenum the results was great, I used:
180
240
320
400
Buffing with 2 vax compounds
Now I started doing the same to the runners, but I have problem with buffing, i get black marks all over the runners. It looks like crap, dont know what I do wrong, any ideas?? are the runners made of aluminium?
//Figge
Old Apr 21, 2003 | 01:20 PM
joshp14's Avatar
Are your buffing wheels black? That's called oxidation from the aluminum. Also, if you are getting a 'rubber' type of material on the runners(yes are made of aluminum), this usually signifies that too much compound is being used.
Take your wheels and toss them in the washer by themselves to give them a good washing. This will obviously clean them and you can re-apply the compound sparingly and you will start with a clean buff.
Also make sure that you are using one buffing wheel per compound....don't use one wheel for all of the compounds.
Old Apr 21, 2003 | 02:05 PM
figge's Avatar
Yes they are black now and yes I get a rubber type material on the runners..If I use my tumbnail I get scrath it off, Like u said its probably to much compound, I new to this so im still learning
I will wash them and se if I get better results..
Thanks for your fast reply
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Royal_Z
Sep 30, 2015 08:45 PM
