Painting t-tops?
Painting t-tops?
I seen a post where someone didn't like the appearance of t-tops. I'm just wondering that if you wanted to, could it be possible to paint the t-tops to match the rest of your car? How could you do this?
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Yeah, as long as you rough of the glass, just use some sand paper the primer should take to it pretty good, just rought it up pretty good, use a thick primer, then some fine sand paper, get it REAL smooth again then paint it.
Do it to a junk set, cause once you sand that glass you'll need to replace them or get them professionaly repaired if you change your mind.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
