Plenum polishing question: Flat surface?
Old May 29, 2003 | 12:21 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Ok, I have purchased an aluminum plenum extension, and have started sanding it down.
I have a soft foam sanding block, which seems to stay pretty level while I sand. Because the plenum extension has so many curves, I have just been hand sanding, and paying more attention to areas which have pits.
I am wondering if this will make everything uneven, and if it won't polish well once I am finished. Should I be using my sanding block to make sure everything is level? Or does it matter?
(This is my first polishing job, just want to make sure I'm doing it right!)
Old May 29, 2003 | 12:23 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
If you have pits, be careful. If you keep sanding, they may actually get wose
Old May 29, 2003 | 12:49 PM
Christos's Avatar
That sucks. I've donw about 1/2 of the top of the extention already with 120 grit, and it's pretty smooth, very very little pits at this point.
I just don't want the metal to be 'wavy'. Hopefully I won't have to sand more and bring more pits up.
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
hartsmike
Oct 2, 2015 07:11 AM
tcflint
Sep 27, 2015 05:58 PM
