'bird headlight mod opinion
Old Sep 30, 2003 | 10:50 PM
  #51
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Looks pretty good.
I can't wait to find some trim so I can get started on that.
Old Oct 5, 2003 | 08:46 PM
  #52
TZFBird's Avatar
Engine: 327
Well.. I'm having a problem with figuring out how to mount the lights in place. I didn't pull any of the mounting for the lights.. just the trim ring with the bubble-level on it. I figured I'd just mount it to that trim.. but just strengthen it up a little bit. That stuff isn't really that heavy, so I doubt it's going to just fall apart.
If I had some sheetmetal, there really wouldn't be any problems.
BTW: If you have any more pics of how that stuff is mounted in there, I'd appriciate it. If that really works well.. I'd consider looking for that mounting. I just didn't want to have to pull a bumper in order to get it.
Old Oct 6, 2003 | 12:04 AM
  #53
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just thought about this. Are you going to have anything to adjust where the headlights point?
Old Oct 6, 2003 | 08:38 PM
  #54
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
TZ.. when I got my lights, I took the adjuster mounting pieces as well to help simplify things. There were only 3 hex screws holding each in (the high beams, which is what I used, anyways) and I didn't have to remove anything to get to them except part of the nose (front collision). I'll get some pictures when I have some time to take the light out. I tried to keep it simple and able to take apart 'easily'
TA12sec.. if you were asking me (?), I took the lamp, adjusters, mount, everything in one piece, to make sure they are adjustable/operable just as if installed on the original car. On the trim bezel I need to grind out a notch to access the left right adjuster screw. Up down is able to be adjusted w/o having the lights on using the built in level.
Old Oct 7, 2003 | 07:11 PM
  #55
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
well at first glance it just makes your car look like its having a bad hang-over but the more i look at it the more i like it. it looks menacing. definitly a possible project for my bird!
Old Aug 11, 2004 | 12:39 PM
  #56
TZFBird's Avatar
Engine: 327
Has any more been accomplished on this topic?
Deadbird.. we need some follow-up pics to see how it turned out.
Old Aug 11, 2004 | 02:09 PM
  #57
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
yea dude, i am so doign this o my TA, can you do that with 85 headlamps mechanisms? The stoping thing.
p.s. the pics you linked to do not work.
Old Oct 17, 2004 | 07:05 PM
  #58
nolanr0413's Avatar
Car: Trans am
i want some more info on this. I would love to do this on my 85 trans am . I think you should sell a kit to do this . I am definately interested in this . I love it .
Old Oct 17, 2004 | 07:15 PM
  #59
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Yes. Kit. I will buy one.
Old Oct 17, 2004 | 11:27 PM
  #60
deadbird's Avatar
Engine: TPI 305/ v6
Fixed the links so they work now. I forgot about this post when I changed the img names.
As far as making kits.. I'm extremely thin on resources at the moment since I've been sinking alot of time/$$ into my garage so I can eventually move the 'bird into it and do some other side work in there.
Here's a few (as close as I can get) close up shots of the lamp and GP mount bracket. All I did was trim the GP bracket to fit the OEM lamp housing and than make a small bracket from 18ga b.i. sheetmetal. a few holes drilled, some screws and that's all the magic there is to it....
Making/modding pieces isn't the tough part. Getting the stop on both lamps in the exact same place, getting the lamps /brackets in the smae place and making the trim looks the same for both sides is the difficult part. I've still yet to find a drivers side trim piece so.. as seen... still not done.
Hood isn't done either as I have a slightly odd idea for a 'cowl' hood I may try to work on over the winter... time permitting.
85Vortec... to save (me) time I'll just quote from another post
Below is all the info I have about the older lights.
It appears that #1 are the limiter arms that travel with the motor movement. They contact #3 to stop the motor (which would be the limiter switch). You would still have to make a stop peice for the arm to contact and brace against but, the limiter would have to be modified accordingly to the new travel limit. Granted, I'm only guessing about these motors, I could easily be waaay off on their operation.
The other option of using new motors, you'd have to completely rewire everything for the motors as the newer design is a 2 wire motor and only has one relay module (instead of 3wire motors and 3 relays).
If some jackass didn't steal all the 'bird and feiro motors from the yards here, I'd probably get one just to take apart to satisfy my own curiousity.
Old Oct 17, 2004 | 11:28 PM
  #61
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Hey deadbird...dead pics...
Old Oct 17, 2004 | 11:33 PM
  #62
deadbird's Avatar
Engine: TPI 305/ v6
Ha... I know, I know.. I have resurrected them
Old Oct 17, 2004 | 11:38 PM
  #63
redraif's Avatar
Nice...
Most of my stuff will have a similar fate soon. I'm working on breaking up my website into smaller chunks...
Sorry to the people with links to my stuff in threads....
Right now I can't even access my old mainsite...calling cardomain 2morrow....
I may have them wipe the pics off when I restructure the other sites. Then I can start over and have a nice summary and link page like I want...
Old Mar 7, 2005 | 10:24 PM
  #64
hpjspdr4l's Avatar
Car: 89 Firebird
Engine: 2.8 V6
BUMP. was going throuigh my old pms and came across thiis thread. DeadBird just wondering if after all this time if youve finished this lazy eye headlight mod yet? if so pics are def in need. if not then ill still wait lol. im in the process of my own as i type this. and im taking pics of everything so i can make an fyi thread.
Attached Thumbnails 'bird headlight mod opinion-c-documents-settings-jr
Old Mar 7, 2005 | 10:31 PM
  #65
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Try to ignore the bizarre aspect of this car, and focus on its headlight mod. Thats pretty hardcore if you ask me..
Old Mar 8, 2005 | 09:57 AM
  #66
TZFBird's Avatar
Engine: 327
I saw that car at HOTROD Power Tour a few years ago here in Lincoln, Neb.
I never noticed the lights.. just that he put fender skirts on it and chopped the top on a notchback. That part doesn't look too bad though. Guy's got a lot of money to throw around on an F-Body.. that's for sure.
I'm working on Deadbird's style of lights. I'm going to pull the headlight assembys out and start working on them while I'm away from the car.
Old Mar 8, 2005 | 10:02 AM
  #67
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
get them done and someone start making a lazy headlight mod for my 85 , it would be great id buy it.
Old Mar 8, 2005 | 04:04 PM
  #68
hpjspdr4l's Avatar
Car: 89 Firebird
Engine: 2.8 V6
id buy it too. once im done with mine i may make a kit. wouldnt or at least it doesnt seem lik it would be that hard. ill post up the picks of my progress so far when i get a chance later this week.
Old Mar 8, 2005 | 05:48 PM
  #69
305q_ta86's Avatar
Transmission: 5 spd
I'd also buy it.
Old Mar 8, 2005 | 07:01 PM
  #70
redraif's Avatar
Originally posted by redraif
Nice...
Wow finally got the site straight! No help from cardomain mind you! www.redraif.com anyway the headlight stuff on my car is here I plan to one day do as the chopped notchback bird did and mold the headlight doors into the hood! Just had to ever get the corners strong enough
Old Mar 8, 2005 | 11:24 PM
  #71
deadbird's Avatar
Engine: TPI 305/ v6
Both headlights have been done for some time.. the only thing that I lacked was a good drivers trim bezel. Thanks to billsfirebird... he tipped me off to a good on at the local boneyard... I now have the trim piece I need.
Bad thing.. the car is probably going to be torn back apart... I'm not happy with the white...
As far as making a 'kit'.. I wish I could but, I'm spread way to thin on personal projects at the moment as it is.
At the moment... I have most of the outer pieces parts off the motor taken off for cleaning/coating and may start sanding the bay down for yet another new color... still debating on that part.
As it is though.. the 'bird is dead (guess my name is accurate once again lol) on jackstands in my shop.. and probably will be for awhile untill I get caught up with other things.
Old Mar 28, 2005 | 01:03 PM
  #72
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
Originally posted by deadbird
Do not disassemble! Johnny five is alive!!!
Sorry, just reminded me of Short Circut.
Jay
Old Mar 28, 2005 | 02:23 PM
  #73
305q_ta86's Avatar
Transmission: 5 spd
Jay
lmao me too, but I was afraid to say something..
Hey Deadbird.. What are the chanced of you turning this into a kit?
Old Mar 28, 2005 | 02:37 PM
  #74
redraif's Avatar
Jay
Old May 6, 2005 | 12:50 PM
  #75
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
i got my headlight mod partically done just like raifs just mounted a different way.
Old May 6, 2005 | 02:50 PM
  #76
blk91gta's Avatar
Car: 05 silverado quad cab
Engine: 5.3
Transmission: auto
that looks awesome!
Old May 6, 2005 | 03:16 PM
  #77
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
heres another pic showing somewhat of how i mounted them
Old May 6, 2005 | 04:55 PM
  #78
demonbird,
Don't you miss the pop up feature, though? I just don't think that I could ever get rid of the pop up headlights. I do think that making them a little smaller would be great though.
Deadbird, how is the progress?
Old May 6, 2005 | 07:52 PM
  #79
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
no i dont really miss the pop ups to me they ruin the lines of our cars and one night i was out driving around in my car and i hit a bump and both lights when down on this pitch black road and i bout ran off a bridge so i dont trust pop ups no more thats what got this idea off the ground. but it was raifs ideas on lights and stuff so thank her for it i just did the work and mounted mine a different way.
Old May 7, 2005 | 11:41 AM
  #80
redraif's Avatar
Since you eliminated the factory brackets it is a much cleaner install. Do you plan to trim and use the factory plastic headlight cover to go around the new headlights?
I opted to make mine reversable since I did not know what law enforcement would think!
One thing...not sure how to ask this and have it make sence...
I know you made a custom bracket to attach the headlamp door on the car...then mounted the lights to the underside of the door. I assume you hinged the new bracket so you could adjust the headlights. How do you lock it down so it will not come up with the force of the wind when the car is moving?
Keeping the original bracketry that held the door on is what keeps mine locked. I still use the factory pop up motors on manual to access mine. They then lock the doors down when the car is in motion. I just unpluged them from the power source.
Old May 7, 2005 | 04:02 PM
  #81
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
ok well right now i have a heavy duty spring keep it down that is really hard to lift with my hand much less the wind. and the lights are very easy to adjust theres like alot of space to adjust. and i think im gonna try and make the original black headlight cover to work. im coming down to the gathering with them almost done so u can see it then k?
Old May 8, 2005 | 10:07 AM
  #82
redraif's Avatar
Awesome! So you found a way to bring the car! Yeah! I thought i saw a spring in the pics you sent, but i was not sure! Good idea!
Old May 8, 2005 | 01:37 PM
  #83
deadbird's Avatar
Engine: TPI 305/ v6
Deadbird, how is the progress? [/B]
Progress... what's that ?
Seriously though.. I haven't messed with the car in months. I've stripped alot of crap from the engine bay (since there is no 'under the hood'... ha!) but, that's about it. It just sits on stands and is mostly covered up with plastic, waiting.
There's lots of other reasons but, lack of interest in even looking at the car doesn't help much either.
Old May 8, 2005 | 04:13 PM
  #84
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
yah were gonna finish it up this month and put a dealer tag on it and drive it down there. i went to get my radiator fixed and they priced it at $90 but then i found a brand new radiator for my car for $98 plus tax so ima put it in finish the lights and go with it.
Old May 9, 2005 | 10:04 AM
  #85
TZFBird's Avatar
Engine: 327
Awww come on deadbird.. you've been supplying me with the pics to get py projects done. I'm about half done with the headlights after who know when I started. I also need to get the door handles done. Mine are breaking cheap pieces of junk. I was loosing interest in my car as well.. but a ride in a friends Firehawk after the nitrous install quickly threw me back into the swing.
So, I suggest finding a fast ride and you'll be hooked once again.
Old May 9, 2005 | 11:31 AM
  #86
redraif's Avatar
Cool...I'm glad you are coming! Can't wait! Fighting with the emissions on mine now! Fun fun!
Old May 9, 2005 | 10:47 PM
  #87
deadbird's Avatar
Engine: TPI 305/ v6
TZ... I do appreciate the encouraging words.. it does help.
I will get back to the car as soon as I can as I have pleanty of revamps to make to it (mainly with underhood wire/relay hiding and part coating) .
Unfortunately, at the moment, I do have other more important things consuming my time & resources. It is only a lull in the progress though, not the end of it .
"Happy are those who dream dreams and are ready to pay the price to make them come true."
Old Jun 16, 2005 | 10:50 PM
  #88
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
kinda diggin up the past this has been dead for a while but i found something.......weird parsay on ebay check it out.
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6420
Old Jun 17, 2005 | 02:57 AM
  #89
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Ok, call me silly or whatever you want, just hear my idea out.
Since many of you are complaining about the firebird lights and not wanting them to pop up and what not, why dont you do what they did with Knight Rider.
Just put four lamps in the middle of your bumper. I am sure that little cutting out and grinding it to finish would not be a problem. Plus with that white cars bumper it would be a breeze to do. On top of that you just open up some space for the air to get through to the radiator. Just an idea.
Old Jun 17, 2005 | 03:53 AM
  #90
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
the main concern with that is the laws that say headlights have to be a minimum of a certain height off the road....(I think it differs a little from state to state but I'm not sure on that)
for example, WA state requires "Headlamps shall be mounted at a height of not less than 24 inches nor more than 54 inches." (measured from center of headlight to asphalt)
(http://www1.leg.wa.gov/documents/wsr.../97-09-069.htm)
how well known or strictly they enforce the laws though...your milage may vary :P
Old Jun 17, 2005 | 04:49 AM
  #91
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Weird, I was going to post the exact same law.
I've done the exact thing suggested. I've also been pulled over a few times since and haven't been hassled about the headlights being ~18" off the ground. Although with how much the car is lowered, the stock headlights wouldn't be more than ~23" off the pavement.
Old Nov 21, 2005 | 11:13 PM
  #92
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
*bump*
O:-)
*runs off*
Old Jan 5, 2007 | 06:54 PM
  #93
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I looked for different ways of mounting too btu I like the stock black plastic because it goes with the bumper
pic
Old Dec 11, 2007 | 10:09 PM
  #94
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Re: 'bird headlight mod opinion
Yo, I want pics and info on this!
Old Dec 12, 2007 | 08:26 PM
  #95
deadbird's Avatar
Engine: TPI 305/ v6
What part of 'this' are you wanting info on ?
I can tell you there are no updates on my end as the 'bird has been a dead project for well over a year now (maybe two even) and will probably continue to sit under a blanket untilll I can get my shop rebuilt and start saving some $$ after moving.
Old Dec 13, 2007 | 07:53 AM
  #96
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
so it truly is a "deadbird".
Are you still in the same location or are you building a new shop somewhere else?
I thought you had already built a shop.
My bird is still alive, however, I don't drive it anymore.
-bill
Old Dec 13, 2007 | 10:18 PM
  #97
deadbird's Avatar
Engine: TPI 305/ v6
-bill
Ohh.. somebody is a funny guy....
Old Dec 15, 2007 | 06:06 AM
  #98
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
C'mon Deadbird, you've had 4 freakin' years to give us the ultimate Firebird headlight mod! We want updates damnit!!!
Old Dec 15, 2007 | 12:53 PM
  #99
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Old Feb 26, 2008 | 11:42 AM
  #100
TZFBird's Avatar
Engine: 327
Well, I might as well bring this back up to the top again. I moved a few times since starting on the project and everything got lost and spaced off. Just this last weekend I found the beginnings of the trim rings. I'm off to Auto Body Supply here in a bit for some resin and matting to finish them up. As far as adjustability goes, I'm going to make a bracket that will hold the smaller bulb in the factory location so I can use the old bucket to adjust the light. Hope it works.
It's finally getting warm again so as soon as we are hitting consistent 40's during the day I'm going to get a lot done.
