how do u think this looks?
Old Aug 1, 2003 | 10:59 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i was thinkin of not puttin louvers back in but paintin the area black just like the head light pockets, kinda gives it an older muscle car appeal without the hassle of the plastic louvers. btw thanks chris for the photoshop.
Old Aug 1, 2003 | 11:39 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Looks sweet, never was too fond of the plastic louvers.
Maybe cut small holes and make them functional?
Old Aug 1, 2003 | 11:42 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
i was hopin that itd be like the 82-84 style but the back of the recess doesnt allow enough room to do so. if i got real crafty with some sheet metal and a welder i could probably fit in a peice at an angle, weld it in, do soem grindin and add some filler, then cut out a section of it.
Old Aug 2, 2003 | 12:20 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I don't think it will look too bad if you fill in the holes.
It'll be a lot easier when you dry your car- I hate how the louvers always seem to have some extra water hiding under there that seeps out when you start driving it.
Old Aug 2, 2003 | 12:28 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
yeah id have to dolley out the bumps and weld the holes, grind it, fill, sand yadda yadda yadad
Old Aug 2, 2003 | 05:52 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I like the louvers and think you should keep them, but if you like the look of the early hood just get it. Maybe hook it up to open when you give it throttle as some of them did stock, it'll look cool even if it's not functional much.
Old Aug 2, 2003 | 09:39 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I say go for it.
The louvers do suck after you washed your car, that irritates the crap outta me when it all drips down the nose.
Old Aug 2, 2003 | 10:15 AM
StealthElephant's Avatar
Car: 87' Iroc
You could fabricate working louvers, that open and close like blinds, except they would connect to your manifold and run off your engine vacuum...or you could have some linkage that you pull/push to open and close them, or you could try and attach it to your throttle cable....I'm going to try the vacuum method sometime...
Old Aug 2, 2003 | 11:58 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
i look at it this way, i can always put the louvers back by drillin out the holes again. but i really dont like em.
Old Aug 2, 2003 | 12:04 PM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
I like it without the louvers. I think it would look nice just black.
Old Aug 2, 2003 | 12:07 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
yep im with everyone else here...go for it...itll look good!
