Freshly Polished Irocs...Part 2
Old Oct 23, 2003 | 08:00 PM
SpeedJunkie's Avatar
Car: 88 IROC
Here they are hopefully!
Old Oct 23, 2003 | 08:01 PM
Car: 88 IROC
Old Oct 23, 2003 | 08:04 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Looks sweet man!!! what's on the rim in the first picture?
Old Oct 23, 2003 | 08:19 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Looks Great! Join the Club!
Old Oct 23, 2003 | 08:21 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
What kind of stripper did you use?
Nice job on the polishing
Old Oct 23, 2003 | 08:26 PM
mikes92rs305's Avatar
dont u just love aircraft paint remover?
Old Oct 24, 2003 | 03:40 PM
Car: 88 IROC
Yeah aircraft remover is definalty awesome at taking off that clear!:lala:
Old Oct 25, 2003 | 06:27 AM
Car: 88 IROC
Does anyone know if it is possible to powdercoat just the insides of these wheels/ I was gonna just paint them back to greyish charcoal but I was thinking having them powdercoated would be sweet
Old Oct 25, 2003 | 09:12 AM
5SIZ's Avatar
Car: 1987 IROC-Z
they look very nice! I remember when I did my rims about a year ago, there still holding up.
Old Oct 25, 2003 | 09:13 AM
5SIZ's Avatar
Car: 1987 IROC-Z
they ended up looking good .
Old Oct 25, 2003 | 09:23 AM
FlyinLow89's Avatar
Car: 1995 Formula/2001 GTP
Engine: 5.7 LT1/3.8 Supercharged
Im not sure but I think powdercoating would have to be done first. then polish after. I may be wrong though....stranger things have happened
Old Oct 25, 2003 | 11:58 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Those look great. I hope to finish my polishing this winter now that I have buffing wheels and compounds.
Old Oct 25, 2003 | 04:04 PM
bigals87z28's Avatar
Car: Check The Sig
must... have... thoes... rims... :hail: good job to all of you guys.
Old Oct 25, 2003 | 07:01 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
speed junkie,
can you explain in detail the polishing process you used?
Old Oct 25, 2003 | 07:13 PM
89_IROC-Z_350's Avatar
ok, where do u get the aircraft remover and what r the steps to geting it like that? I have an 89 w/ clear still on...???
Old Oct 25, 2003 | 11:18 PM
Car: 88 IROC
Well I got the aircraft remover from autozone. applied it to everything cause i was gonna repaint the insides and needed the clear coat off from the factory. I then sanded down with 80 or 100 grit(i forget) the inner painted areas, sanded the actual bare alumium with 320 dry, then 400 wet. After the sanding was done I buffed it with my 4 inch wheels and brown compoumd on my die grinder and then buffed it finally with white rouge.
Remember, sanding is the Hardest, most tasking, longest part of polishing. For me it takes me about 2 hours to completly sand a wheel and about 20 mins to buff it out. Without sanding properly buffing does nothing.
Need to learn how to buff aluminum or anything? www.caswellplating.com (i think...) awesome product and business. dealt with them for years now no problems.
It takes a long time to buff a set of wheels so make sure you do it over a long period of time. A wheel a weekend at least for me.
Old Oct 25, 2003 | 11:21 PM
Car: 88 IROC
Almost forgot, 85SportCoupeto89RS, is very good at polishing. Ive been messing around with this stuff for years and he has amazed me with the detail in his parts. awesome work man!:hail: :hail:
Old Oct 26, 2003 | 01:32 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Novass has done what I want to do with the Formula rims that I have in storage. Nice job.
I might try to stip mine later this year and then have the outsides chromed and the insides black. "Pontiac" will be in red.
Jim.
Old Oct 26, 2003 | 01:40 AM
Car: 85 Camaro SC
Engine: V6
Thanks I do my best to make everything that comes thru my shop shine like no other.
Old Oct 28, 2003 | 06:45 PM
Spdfrk1990's Avatar
Hey guys i been workin on my wheels and they just arent gettin as shiney as i like. I used the east wood kit is there nething else i need to do i still see some fine scrathes and i went over it real good till 400 wet. Then buffed like it said. Should i try using some rubbing compund then some finishing glaze?
Old Oct 29, 2003 | 02:16 PM
Car: 88 IROC
Well 400 wet might be too much. try like 320 dry and them buff it out tripoli(brown) compound. Sometimes the cloudiness can come from too fine a grit used.
Old Oct 29, 2003 | 03:30 PM
Spdfrk1990's Avatar
What was the last step u did on yours they look good.
Old Oct 29, 2003 | 04:06 PM
Car: 88 IROC
I sanded dry with 320 then used the Spiral sewn cotton wheel with the brown tripoli compound, then I used the loose cotton wheel aith the white rouge.
Old Oct 29, 2003 | 04:09 PM
Spdfrk1990's Avatar
hmm yeh thats what i used but i went to 400 wet and i still could see some scratch marks tho . i dont know maybe i just need to go over it again and clean it real good
Old Oct 29, 2003 | 05:25 PM
Spdfrk1990's Avatar
heres another 1 i needed to go over it a lil more but i dont see it gettin that much better.
Old Oct 29, 2003 | 05:56 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thats why I'm just gonna bead blast my wheels and have them powder coated in mirror silver.
It seems like too big a pain in the **** to polish them!
I have a blast cabinet with fine glass bead media. Will this take off the clear coat fairly easy? Or should I still use aircraft paint stripper on them?
Old Oct 29, 2003 | 06:15 PM
Spdfrk1990's Avatar
if u have fine glass bead i would blast them u would want to sand them smooth neway b4 u took them to get powder coated either way
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
