SS hood optional?
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
SS hood optional?
Is the LS1 ss style hood that i see on many of the third gens in here functional??
If so, can u post an under hood pic?
Car: Camaro
Im not sure if it comes with the scoop cut out or if it has to be done when you get it, I think some are some arent. To get it truely functional you have to make an air box to direct the incoming air through a filter into the engine. Im not sure if that is an aftermarket buy or a do it yourselfer either. It has been done use the search and you will find it im sure.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
