How to align hood with headlight and front nose
Old Dec 25, 2003 | 08:35 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
How would I lower the front of my hood to be in line with the front bumper? It bugs me everytime i see it.
Old Dec 25, 2003 | 10:17 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
First thing, how does it line up at the sides by the front of the fender/nose? If it's high there, you can turn down the rubber bump stops on the upper rad support a bit, and lossen the bolts holding the latch mechanism to the support, and lower it a bit also. If it lines up good along the fenders, you might lower the latch a bit, or install some washers to raise the back edge of the nose up a bit. The washers will go under the screws that hold the nose to the fiberglass headlight bar.
Pete
Old Dec 26, 2003 | 09:08 AM
ZROC86's Avatar
Transmission: A4
Hey thanks man I'll try the bump stop thing. It's high at the corners and a little in the middle but that should be fixed at the same time.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
