17" Torque Thrust II wheel specs
Old Feb 18, 2004 | 07:29 AM
FocusGhia's Avatar
Car: 88 Camaro IROC T-Top - Gunmetal Grey
Engine: 305 TPI V8
17x9.5" with 275/40x17 all around
5.5" backspacing for the rear
5.25" for the front
This is the only info I found on Torque Thrust II rim specs when I did a search.
I want to order these for my grey 88 IROC (which will be lowered approx 1-1.5" and has drums on the back)
Can you guys confirm this is the correct specs before I make an expensive mistake?
Also, will this throw the speedo reading out?
I have the std 16" IROC rims at the moment.
Old Feb 18, 2004 | 01:20 PM
nolanr0413's Avatar
Car: Trans am
thats correct, thats what chevyken has on his car and his car is lowered too, so thats what im gonna use for bs when i get some rims.
Old Feb 18, 2004 | 05:31 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
yup, as mentioned - those are the specs I use with the car lowered 1.5"
All the details are here: http://www.chevyworld.net/iroctt2.htm
Ken
Old Feb 18, 2004 | 07:45 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
I want to be able to rotate my tires ( my cars is the everyday driver ) So do you think if i went 5.5 bs all the way around i would have a problem? Would it look weird in the front?
Old Feb 19, 2004 | 11:02 AM
nolanr0413's Avatar
Car: Trans am
it wont look wierd, the slp ronal firehawk rims has a 5.5 bs all the way around, but they also come with a 1/5 inch spacer so that if you have a non 1le car the rims wont rub, i think you could order them in all 5.5 and see if it hits, then runs the stock rims for a while. in that time you could have a 1/4 inch spacer made at a machine shop or buy some.
Old Feb 19, 2004 | 11:40 AM
FocusGhia's Avatar
Engine: 305 TPI V8
So if I order wheels in 9.5" width I need to 5.5" backspacing for the rear, and 5.25" backspacing for the front.
And if they don't make 5.25" backspacing I can order 5.5" backspacing and use a .25" spacer?
Old Feb 19, 2004 | 12:38 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Again, check the link I posted above. It is all there.
Basically most people, as far as I know, are running 5.5" around, but I prefer the extra clearance from the tie rods to prevent rubbing.
Ken
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
LT1Formula
Nov 16, 2015 01:13 PM
gwade12
Aug 8, 2015 08:17 AM
