Can you get z06 rims in black?
Old May 13, 2004 | 08:15 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Can you get z06 rims for a thirdgen in black?
Old May 13, 2004 | 09:04 PM
nolanr0413's Avatar
Car: Trans am
no zo6 rims are made for a thirdgen yet. To run they u need to get adaptors to get the correct offset. I think ive seen replicas on ebay . so check the bay.
Old May 13, 2004 | 09:26 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Is there a rim with a 10 spoke design that fits thirdgens? Preferably in black?
Old May 13, 2004 | 09:30 PM
Mr.W's Avatar
Car: 91 RS
Engine: 305 TBI
Transmission: Stock auto
OE concepts makes a Z06 rim in black with rivets around it, I dont know if it's available without rivets, but here it is
http://www.oeconcepts.com/2004/z06rivets.html
their for a vette so you'd still need adapters.
Old May 13, 2004 | 09:32 PM
stiers's Avatar
You are probably going to have to get the backspacing custom made for the thirdgen. Lots of companies do custom backspacing. Find a wheel you like and call the company and see if they can do it.
Old May 15, 2004 | 05:04 PM
Kandied91z's Avatar
very few cast wheels fit a thirdgen. custom backspacing in a cast wheel would run you a fortune. just either build a set of billet wheels or go with the heavier cast wheels like oe concepts makes but then be prepared to pick up adapters to bolt them to your hubs.
Old May 18, 2004 | 02:09 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
If you get the rims with the rivets, do you need special tires? Hows that work?
Old May 18, 2004 | 02:12 PM
Kandied91z's Avatar
the rivets are FAKE....typically a wheel with rivets has rivets because it's a 3 piece wheel which means if you damage a wheel while racing you can remove the rivets and put a new face on. this is also unique for show cars that want to change things up a few years down the road. you just purchase a new face for a fraction of what a new wheel would cost and off you go.
for cast wheels like the z06 they are purely for looks and don't mean anything. either way rivets do not change how you use your tires. just a difference between riveted to the barrel or welded like a 2 piece wheel.
in a cast wheel they are basically molded on or in an easier sense glued on but without glue since that wouldn't hold.
Old May 18, 2004 | 08:09 PM
Dirtbik3r's Avatar
Damn, your just full of all sorts of info Kandied. Thanks. I do like the rivited look though . Whats everyone elses opinion here? Rivets or no Rivets?
Old May 18, 2004 | 08:39 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
The rivets look mean on C5's... cant imagine they would look bad on a third gen
Old May 18, 2004 | 08:44 PM
FLYNLOW92rs's Avatar
I'm a fan of rivets, but I have fewer rivets then the Z06 pictured.....But the rivets i like are chrome with the wheels....
A little dirty....Pictures like these only highlight the need for me to get 13" baer brakes.....
Old May 18, 2004 | 10:05 PM
iroc-ice's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
The black Z06 wheels with the chrome rivets look mean. I think its time to start saving up.
Hotrodboba400
Dec 10, 2019 07:07 PM
birdman_29
Jan 7, 2017 08:24 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
