85 GFX to 90 GFX?
Old May 18, 2004 | 05:41 PM
JestahX's Avatar
Car: '85 Z28 Camaro
85 GFX to 90 GFX?
In the process of repainting, have a problem with the front valance being cracked and the side GFX aswell. Want to get new instead of fixing and would like to use 90's GFX instead because it has a better look to it. Will this work???
Also will the front bumper off the 90's camaro work for my car aswell?
Its an '85 Z28
Heres an in progress pic:
Old May 18, 2004 | 06:11 PM
pardonme2711's Avatar
i am assuming u mean the 91,92 gfx with the little scoops on the sides. if so then yes those and the front bumper will work, you might have to drill a couple new holes but other than that they will fit fine.
Old May 18, 2004 | 06:58 PM
JestahX's Avatar
Car: '85 Z28 Camaro
Right on, thanks a lot
Old May 18, 2004 | 08:46 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I just swapped my 89 GFX for some 91-92 GFX. You have to drill some new holes and elongate some others, but its not a very hard swap to do. Pics are on my website, link is in the sig.
Old May 18, 2004 | 08:49 PM
FLYNLOW92rs's Avatar
Minor Modification = Great Improvement
A few minutes with a drill is all it should take, are you replacing the rear gfx pieces as well?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
snakeshooter
Sep 7, 2015 11:15 AM
LittleFranks
Aug 20, 2015 03:55 PM
