Rotating Tires???
Rotating Tires???
I've got a '91 Z28 and i need to rotate my tires. I noticed that on my rims the rear rims say REAR and the front rims say FRONT. Does it matter if put the rear tires with the rim to the front? Or, do i have to remove the tires and just rotate the tires instead of the whole wheel. Are the Front and Rear rims different or what?
-Todd Scharwath
1991 Z28 5.0 TPI Convertible
-Todd Scharwath
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The backspacing is different,, the wheels cannot be rotated, except side to side.
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
Virtual Racing
- intelligence is learned, ignorance is universal
84 Camaro</A>
Virtual Racing
Engine: TPI 305/ v6
<table border="0" width="610">
<tr>
<td> <p><font size="4" face="Arial"><b>TS-W302F</b></font>
<table border="1" cellpadding="5" cellspacing="1" width="531">
<tr>
<td width="33%"> </td>
<td width="47%"> </td>
<td width="20%"> </td>
</tr>
<tr>
<td width="33%"><font size="2">Nominal Diameter
(In)</font></td>
<td width="47%"><font size="2">Kondiameter</font></td>
<td width="20%"><p align="right"><font size="2">12"</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Fs (Hz)</font></td>
<td width="47%"><font size="2">Resonansfrekvens</font></td>
<td width="20%"><p align="right"><font size="2">33,4</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Qms</font></td>
<td width="47%"><font size="2">Mekaniskt Q-v�rde</font></td>
<td width="20%"><p align="right"><font size="2">17,754</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Vas (l)</font></td>
<td width="47%"><font size="2">Ekvivalent
luftvolym</font></td>
<td width="20%"><p align="right"><font size="2">105,62</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Cms (mm/N)</font></td>
motst�nd i upph�ngningen</font></td>
<td width="20%"><p align="right"><font size="2">0,286</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Mms (g)</font></td>
<td width="47%"><font size="2">Konvikt</font></td>
<td width="20%"><p align="right"><font size="2">79,49</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Rms (kg/m)</font></td>
<td width="20%"><p align="right"><font size="2">0,94</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Xmax (mm)</font></td>
<td width="47%"><font size="2">Slagl�ngd</font></td>
<td width="20%"><p align="right"><font size="2">6</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Sd (cm2)</font></td>
<td width="47%"><font size="2">Effektiv konarea</font></td>
<td width="20%"><p align="right"><font size="2">511</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Piston dia. (cm)</font></td>
<td width="47%"><font size="2">Konareans diameter</font></td>
</tr>
<tr>
<td width="33%"><font size="2">Mounting diameter
(cm)</font></td>
<td width="47%"><font size="2">Monteringsdiameter</font></td>
</tr>
<tr>
<td width="33%"><font size="2">Qes</font></td>
<td width="47%"><font size="2">Elektroniskt
Q-v�rde</font></td>
<td width="20%"><p align="right"><font size="2">0,494</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Re (ohm)</font></td>
<td width="47%"><font size="2">Impedans</font></td>
<td width="20%"><p align="right"><font size="2">3</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Le (mH, vid 12
kHz)</font></td>
<td width="47%"><font size="2">Talspolens
induktans</font></td>
<td width="20%"><p align="right"><font size="2">0,618</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Z (ohm)</font></td>
</tr>
<tr>
<td width="33%"><font size="2">BL (T*m)</font></td>
<td width="47%"><font size="2">Motorfaktor</font></td>
<td width="20%"><p align="right"><font size="2">10,225</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">R.M.S. Power (W)</font></td>
<td width="47%"><font size="2">Nominell
effektt�lighet</font></td>
<td width="20%"><p align="right"><font size="2">150</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Qts</font></td>
<td width="47%"><font size="2">Totalt Q-v�rde</font></td>
<td width="20%"><p align="right"><font size="2">0,481</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Efficiency (%)</font></td>
<td width="47%"><font size="2">Effektivitet</font></td>
</tr>
<tr>
<td width="33%"><font size="2">S.P.L. (dB/Wm)</font></td>
<td width="47%"><font size="2">K�nslighet</font></td>
<td width="20%"><p align="right"><font size="2">94</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Max Music Power
(W)</font></td>
<td width="47%"><font size="2">Maximal
<td width="20%"><p align="right"><font size="2">450</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Sp. Displacement
(l)</font></td>
h�gtalarvolym</font></td>
<td width="20%"><p align="right"><font size="2">2,02</font></p>
</td>
</tr>
<tr>
</tr>
<tr>
<td width="33%"><font size="2">Vd (l)</font></td>
<td width="47%"><font size="2">Max slagvolym</font></td>
<td width="20%"><p align="right"><font size="2">0,306</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Zmax (ohm)</font></td>
<td width="47%"><font size="2">Impedans vid
resonansfrekv.</font></td>
<td width="20%"><p align="right"><font size="2">114,2</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Magnet Wt (g)</font></td>
<td width="47%"><font size="2">Magnetvikt</font></td>
<td width="20%"><p align="right"><font size="2">1240</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Flux Density
(Guass)</font></td>
<td width="47%"><font size="2">Magnetfl�de</font></td>
<td width="20%"><p align="right"><font size="2">10500</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Magnet Gap L. (mm)</font></td>
<td width="47%"><font size="2">Magnet glapp</font></td>
<td width="20%"><p align="right"><font size="2">10</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">V.C. Lenght (mm)</font></td>
<td width="47%"><font size="2">Talspolens l�ngd</font></td>
<td width="20%"><p align="right"><font size="2">22</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">V.C. Diameter (mm)</font></td>
<td width="20%"><p align="right"><font size="2">48</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Vas (ft3)</font></td>
<td width="20%"><p align="right"><font size="2">3,73</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Vd (ft3)</font></td>
<td width="20%"><p align="right"><font size="2">0,0108</font></p>
</td>
</tr>
<tr>
<td width="33%"><font size="2">Sd (ft2)</font></td>
<td width="20%"><p align="right"><font size="2">0,55</font></p>
</td>
</tr>
</table>
<p align="left">
</td>
</tr>
</table>
<tr>
<tr>
</tr>
<tr>
(In)</font></td>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</tr>
<tr>
(cm)</font></td>
</tr>
<tr>
Q-v�rde</font></td>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
kHz)</font></td>
</td>
</tr>
<tr>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</tr>
<tr>
</td>
</tr>
<tr>
(W)</font></td>
</td>
</tr>
<tr>
(l)</font></td>
</td>
</tr>
<tr>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
(Guass)</font></td>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
<tr>
</td>
</tr>
</table>
<p align="left">
</td>
</tr>
</table>
Car: 90 Formula, blue/silver
Engine: 305 TBI
When you rotate, your front tire will go on your rear rim on the same side, and vice-versa. I had new tires put on last year, and the bonehead "technician" at the Firestone dealer (yes, Firestone...) put the passenger side front wheel on the rear, and vice versa. Pulled out of the lot and the tie rod end on the right front was hitting the inside of the rim, due to the different wheel offsets. So, watch those idiots when they work on your car...
90 TBI 305 Formula
Original Owner
Auto Trans, T-Tops
Completely Stock Except:
--Flow Cooler water pump
--180 T-stat
90 TBI 305 Formula
Original Owner
Auto Trans, T-Tops
--180 T-stat
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
