Fuel Pressure Gauge Installed!!!
Old Nov 21, 2004 | 03:10 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
It has been installed since around July but I have finally got around to taking a few pics. It is a really handy to have so you know if you are getting enough fuel pressure. It is cool seeing the gauge move and see how the pressure fluctuates from hitting the gas and letting off the gas. Here are of few pics of the gauges installed. The last one is the only pic I have of the gauges lit up at night I will take some better night pics soon.
Here is the sending unit intstalled on the fuel rail
Old Nov 21, 2004 | 04:36 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
looks good man. I installed a fuel pressure gauge underneath my hood...wished I would have spent the extra cash and got the electric fuel psi gauge though
I noticed you have the 3 pillar pod....what is the next guage your going to install? Nitrous PSI or Boost?
Old Nov 21, 2004 | 04:52 PM
Gambit69's Avatar
Actually all 3 of them are filled right now. The top one is a volt meter gauge. If I decide to switch that one out it will more than likely be a nitrous psi gauge because I am toying with the idea of putting nitrous on it in the spring. It will only be either 75 or 100 shot but I don't plan on using it that much. Will use the purge valve more than anything.
Old Nov 21, 2004 | 11:20 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
That gauge cost how much? I just did a quick search on Jegs and it was up in the $150 range?
Looks awesome by the way, but damn that's expensive.
Old Nov 22, 2004 | 12:21 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
thats looks good bro. what are you going to put in the empty one?? im going to do that too i dont know when. how much did you pay for the gauge pod??
Old Nov 22, 2004 | 12:22 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
looks good
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
