tire size
Old Feb 24, 2005 | 11:52 AM
91Z28CAMARO32's Avatar
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
tire size
whats the fatest tire you can put on a 91 z28 and what size rim
and what the offset is
Old Feb 24, 2005 | 03:36 PM
Car: 91 Z28 CAMARO
gee i guess nobody knows
Old Feb 24, 2005 | 03:40 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
or everyone knows and would rather have you do a search, becasue someone asks questions like this every other day.
but I will be nice and tell you. Stock is 245/50/16 but you can run a 255/50/16 if you want to. the ofset is 0. +5 for the front on some. check out this link too for further size questions.
http://www.miata.net/garage/tirecalc.html
edit: or you could go look at the tires on you 91 Z28, assuming they have the stock wheels one them.
Old Feb 24, 2005 | 04:32 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
you can fit up to 275's thats what mw66nova is running, but his arent the Z28 rim though.
Old Feb 24, 2005 | 05:05 PM
VILeninDM's Avatar
I am planning on buying 275-40R17's with 17x9 or 17x9.5 rims. Offset should be the usual one for our cars. I will be running 4th gen rear so I am buying adapters for the fronts and will be running with 4th gen offset.
Don't think you can get bigger than this without doing some hacking and massaging
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
