Need Help!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 24, 2005 | 08:25 PM
fattdaddy's Avatar
Car: 1992 Rs
Taking the rims off my camaro the last owner had on it. He used the those stupid Fing lug nuts that use a key in the shape of an Hex, I get them all off and go to take the last one off and in is striped so bad that nothing will catch the inside and there is no space in between the outside of lug nut and the rim. If I need too I'll take a pic please help!
Old Feb 24, 2005 | 08:54 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
OH MY *** YOU ARE SO SCREWED.....might as well give the car to me man....terribly sorry......
haha just kidding dude, try one of those drill bits that grab anything
Old Feb 24, 2005 | 09:23 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Can you hammer a 12 point socket on there?
Old Feb 25, 2005 | 04:19 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
The locks, my dad hates those things since he had a bad experiance, take it to a tire joint and see if they might have a key for it......all those are the same basically i think
Old Feb 25, 2005 | 08:43 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
listen man you can go to discount tire and have them break them off for you but they charge to do it...if you have a buddy that works at one see if he'll do it for you for free other wise you can get cerated sockets that you hammer on and then try wrenching it off yourself
me personally id probably just pay or have a friend do it bc i think its like 5 bucks to break each lock and its well worth it if you need them done without having to take the time to go buy a kit and do it yourself....discount tire will even give you a new regular lug too
Old Feb 25, 2005 | 08:49 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
if you have access to a welder, just weld a regular lug nut to it. Then just remove it. Be carefull not to get weld splatter on your rim. Just a few spot welds and it could be off.
