removing decal but then putting it back on
Old Mar 6, 2005 | 01:20 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I need to remove the emissions decal under the hood. How should I do this without damaging the decal? I've read lots of ideas on removing but which way is best for actually saving the sticker? I'm getting the hood painted on the underside and need this sticker.
Old Mar 6, 2005 | 01:33 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Oh brotha where at thou!this is a tough one!My best advice is very slowly and carefully.Hopefully some one has better advice than me.Good luck
Old Mar 6, 2005 | 02:04 PM
Megaracerx2's Avatar
On Probation
Car: 1986 Trans Am
maybe heat it up? and then it might come of easier..
Old Mar 6, 2005 | 02:50 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
tape it up. cover it with tape then cut along the outline with a sharp rasor. it works great. the problem with taking these stickers off is that some off them arent ment ot come off. im not sure if this is the case on our cars or not but when tring to peel these off the sticker will seperate into two halves and the works void will appear on the sticker. its tough to explain. viold will be in clear letters will remain on one half and the sticker will rip off with void in clear letters. i donno if this hepls you but ur best bet is to tape it up.
matt
Old Mar 6, 2005 | 02:51 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
someone correct me if I am wrong but doesn't classic industries carry all of our stickers? so you could just order a new one
Old Mar 6, 2005 | 03:56 PM
Greg's Avatar
Ahh well the plot thinkens...I'm probably getting the hood chemically dipped to strip it, so I can't tape it up either. What's the number for Classic Industries?
Old Mar 6, 2005 | 04:44 PM
rsn932's Avatar
there is a part number on the bottom right-hand corner of the sticker. they are very very cheap to buy new ones. when you try to peel the old one off, you just peel off the coating and ruin it. i've heard the numbers stay on the hood or they disappear. best bet is to just buy a new one.
Old Mar 6, 2005 | 04:45 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Go here:
http://www.classicindustries.com
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
