Paint Job?
Car: 87 Z28
Engine: uh does the name give u a hint
Paint Job?
Hey guys i was just wondering whats the best way according to ya'll to get the old paint off the car besides, Carb Cleaner, Brake Fluid, and Acitone?
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
"DA" is short for the Dual Action Sander. It is an orbital sander that is weighted on 1 side of the pad and has 2 pivot points. It allows the pad to move in multiple directions at once so that the pad is not constantly spinning in one spot.....
Car: 86 Iroc-Z28
Engine: FB385
What they said. You could be there forever wiping it down with a paint remover. Even than you would have to spend more time on wiping off the chemical before re-paint!
Not very effective if you are paying someone. But if you have the time, why not?
Transmission: yes
Chemical paint removers are usually not very fun to work with. The cleanup is a PITA and you have to be VERRRRRRRRY careful to get it all off before you lay any primers or paint down. Some primers will even lay down fine over some strippers and you won't even see the problem until you lay paint and it just peels away.....
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
