WHEEL FITMENT++READ++
I always see people asking how big can i go
This is a list of the Biggest Meats you can tuck under a thirdgen at full jounce and rebound :
15-INCH 15x8 with 4 1/2-inch backspacing front and rear. Use tires with an aspect ratio of 55 or less with a section width of 255
16-inch 16x8 with 4 1/2-inch backspacing front, 5 1/8 backspacing rear. Use a tire with a aspect ratio of 55 or less and a section width of 255
17-inch 17x9 with 5 1/2-inch backspacing front and rear. Use tires with an aspect ratio of 40 or less with section widths of 255 front, 275 rear
18-inch 18x9 1/2 with 5 1/2-inch backspacing front, 18x10 with 6-inch backspacing Use tires with an aspect ratio of 35 or less with section width of 275 front, 275-295 rear
Hope this help's some to make their thirdgen the baddest on the block
hey just to let u know i fit a pair of 275/60/15 tires on a pair of 86 monte SS rims on my 87 and they fit fine didnt rub once, so 255 isnt the biggest u can go with a 15 inch rim ,
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Car: 91 Red Sled
Thanks, I was just talking with my friend about the next set of tires I'm getting. Here is my question though. What if I have 1.5" lowering springs? Does that change anything in the front? I have 16x8 245/50 right now and I want to put on 255/55.
, Jon (91 RS too many mods to list), getting new engine in summer
you can use larger tires. I saw a 91 T/A at a carshow that had 17x10s out back with 315s. Look like a friggin steamroller from the back.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
drptop70ss
Oct 4, 2015 09:44 PM
punkmaster98
Sep 8, 2015 09:45 PM
