87 trans am tailights on 91 firebird
Old Sep 16, 2005 | 03:31 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
i just won a pair of 86-87t/a tailights im not sure its one of those yrs but any wayz is this a direct replacement? or is there somethign else thats needed to make the swap work ?
Old Sep 16, 2005 | 03:58 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
do a
Old Sep 16, 2005 | 06:13 PM
MoroteZ28's Avatar
i did foudn nothing helpful
Old Sep 16, 2005 | 09:20 PM
llvll4l2c91350's Avatar
pretty sure u have to mess with the wiring seeing as the brake and turn signals light up differently between both sets.
Old Sep 18, 2005 | 05:17 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you have the standard Firebird lights with the amber on the bottom corner, you will need to change the outer bulb connectors since the ones you have are too long, and just unplug the tiny bulbs.
this will make the lights work like this:
Drivers side: outer is the turn signal and will only light up with the turn signals and hazards. The two inner ones will be the running lights and brake lights.
alternativley, you can get another bulb socket with pigtail for one of the small lights, drill a small hole in the outer side where the turn signal light is so that the entire panel will light up with the parking lights. This is what I did with my 88 Formula when I had my Trans Am lights on it. I don't have the lights anymore so I can't show you what I did.
Old Sep 18, 2005 | 09:34 PM
Mr. TurboTA's Avatar
They lite up as stated above.
However, I got a extra set of reverse light pigtails from a '85-'90 Trans am, and wrapped the big '91 end pigtail in plastic and tirwraps, and ran the '87-'90 reverse light pigtails along side the now wrapped pigtails, and spliced them together with the special blue plastic clips that splice two wires together without and cutting of wires. I just pushed the '91 pigtails out of the way of the taillights.
I like how it looks/works!
Good luck with yours,
George
Old Sep 19, 2005 | 03:21 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Originally posted by 1987GTAowner
do a
lmao...
For the poster! Sure it will look good but something about putting TA lights on a Bird seems morally wrong....
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Thomas
Oct 3, 2015 05:34 PM
