Simple Green and Polished Surfaces
Old Nov 23, 2005 | 03:25 PM
SKFengineer's Avatar
Car: '87 IROC (TPI 350), '01 Corvette, '
Engine: '90 Corvette 350, blueprinted and b
Transmission: 700 R-4, with stage 2 shift kit
I tried doing a search, but I didn't see anything that without a doubt answered my question.
What I need to know is will Simple Green, straight or mixed 2 to 1 with water, hurt the clear coat on my IROC rims or the polish on my Vette wheels.
Thanks for the help.
Old Nov 23, 2005 | 07:08 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Simple Green states on the bottle not to use it on aluminum. However - in my bicycle racing days we used to use it on aluminum all the time as high end racing bikes have all sorts of aluminum components hung on them, regardless of what the frame is made from (aluminum, titanium, carbon fiber, steel) and I never had a problem with it.
I'd either cut it 2:1 with water or, if you have a Costco membership then get a gallon of Kirkland All Purpose Cleaner and cut that 10:1 instead. If you have a shop near you that sells the Meguiar's Detailer Line or Meguiar's Professional Line (that's right, this is NOT the consumer stuff you normally pick up at the auto parts store down the street) then get Meguiar's All Purpose Cleaner and cut it 10:1.
The fact that you have a clear coat tells me any of the above products will be OK for you, but I would definitely either wax those wheels or, better yet, apply a coat of sealant to them (like Zaino, Meguiar's NXT, etc). It will make brake dust cleanup totally painless in the future.
Old Nov 27, 2005 | 05:28 PM
So what your saying is that I don't need to worry about Simple Green on the clear coat of my wheels?
Old Nov 27, 2005 | 05:41 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
+ a tooth brush, works wonders! Safe on rims, and cleaned mine up perfect! Even the hard to remove spots.
Old Nov 27, 2005 | 11:21 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
doesnt fast orange have grit in it? I wouldnt recomend using grit on an expensive wheel...
Old Nov 28, 2005 | 12:46 AM
Car: 1988 IROC-Z
Engine: 427 SBC
It will not harm a stock clear coated IROC wheel. I wouldnt use it on a highly polished wheel. Should of said that. Although I still think if you used it on a polished wheel with care, you'd be fine.
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tcflint
Sep 27, 2015 05:58 PM
