Foggy Running lights
Old Feb 27, 2001 | 10:14 PM
Camarogofast's Avatar
The front turn signal lights on my 89' RS are fogged up with water condestion. What can I do to get rid of the water in the lights?
Old Feb 27, 2001 | 10:23 PM
zee28's Avatar
Car: 86 iroc
nothing.there is a fix for it somewhere on this site but it involves cutting and alot more work then replacing them.People will tell you they can be polished,but they will never compare to new ones.It makes a huge differance too.Its not just the water in them,its scratches from over the years.And when or if you get new ones you will see why they scratch so easy.Dont rub on them when washing or drying.
~mike~86 IROC-Z
Old Feb 27, 2001 | 10:25 PM
RARE-ROC-Z's Avatar
there was an idea here once to drill a couple 7/32" holes in the top of the housings and a few on the bottom on the back side. that way air can get through. and the water can drain out the bottom. this will also allow you to run 20W bulbs instead of the 10W bulbs so you can look like the new Fbodys, with the bright driving lights. that is just a thought. and if you have them out. why not coat them in black clear coat. to give them that tinted look. just an idea. good luck man and have fun
1990 IROC-Z L98/G92 350 TPI
too much to list!!
5,507 IROC's; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
MUSTANGS...ONLY 4 LUGS....HAHA THAT IS HILARIOUS.
Old Feb 27, 2001 | 11:44 PM
Fastcamaro87's Avatar
u can take them out and use a blow dryer to dry them out, then get some meguiars plastic polish and a buffer,and polish the heck out of em, no they will not look as good as brand new ones but it is still one hell of a difference, and as far as stopping it from happening again, just take some rtv and fill up the vents on them, i did this about 6 months ago, no more fog.... and no problems..
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Feb 28, 2001 | 12:27 AM
Thanks for all the help guys. I think I know what to do now.
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
