Can you get 275 tires for 16inch wheels? I know you used to be able to get Comp T/A VR4 for a 16inch wheel in 275/50VR16. You can get a General XP 2000 II RWL in 275/55-16, which I don't want. And you can get some slicks. Why doesn't any make wide tires for 16inch wheels? If you know where I can get some, please let me know. Thanks.
Danny
deutsch1@marshall.edu
Black, 1989 Camaro IROC-Z, 350 TPI
150 H.P. NOS, Progressive Controller,Comp Cams 1.6RR & Valve Springs, AFPR, Ram Air, K&N's, Airfoil, Ported Plenum, Accel 300+ Wires & Supercoil, !Cat, Flowmaster, Trans-Go Shift Kit, SFC's, STB, Goodyear F1's, Zainofied, T-Tops, Etc...
Check out my Webpage
Danny
i have seem them done b4 on back of an iroc. It makes it look like a farm tracter becouse the rears are so much wider than the fronts. It wouldnt even fit on the fronts w out rubbing n e way.
