Powdercoating
Old Jun 13, 2006 | 06:55 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Powdercoating
Why are you supposed to use a non-food oven? What's wrong with baking the parts in the kitchen oven?
Old Jun 13, 2006 | 06:59 AM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
it gives off toxic chemicals when it bakes . not worth risking it .
Old Jun 13, 2006 | 07:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
That's messed up. It says right in the manual that...
"Are any toxic fumes generated during the cure"?
"As with any coating process you must cure the powder in a ventilated area. The powder does not contain the VOC's (volatile organic compounds) associated with solvent based aerosol coating but you may notice a slight odor as the metal is heated to 400F"
The manual doesn't really even answer it's own question.
Old Jun 13, 2006 | 08:39 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
That is messed up.
The other problem with the kitchen oven is that most of them won't fit any decent sized parts like intakes and stuff.
Old Jun 13, 2006 | 11:53 AM
Leader_One's Avatar
Car: 1990 TA, 1995 Sierra 1500
Engine: 305tpi to LT1 mod, 305 TBI
Transmission: 4L60E with 3000 Stall, 5spd
When i worked at a custom powdercoating shop the oven pushed a lot of air inside as well. I would never use home oven for powdercoating.
Old Jun 13, 2006 | 05:27 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I guess I'll just shop for an IR light.
Thanks guys
