Strut Tower Brace
Old Dec 18, 2006 | 11:08 AM
  #51
erikcamaro89's Avatar
thanks to this car club i have learned yet another thing about my car.
i definitly noticed this last summer strut poping on my passenger side. im replacing my front struts, and putting in a eibach lowering kit. this brace will help my car out quite a bit!
Old Dec 18, 2006 | 11:57 AM
  #52
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally Posted by irocz1228
will a stealth ram intake fit under those?
Not at all.
Old Dec 18, 2006 | 12:41 PM
  #53
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Well no one has a TPIS bay brace? Here is mine, I powdercoated it.
Old Dec 18, 2006 | 06:04 PM
  #54
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
that TPIS brace looks pretty sweet!
Originally Posted by MARO-MAN
What all has to be taken apart to install these bars? Inner fenders have to come out? I read somewhere that some year 3rd gens have a thinner firewall lip then other years. Anyone have a problem with mounting issues on the back firewall with the 3 point mounts?
Would this be a first good suspension, besides SFC? Or is money better spent in the rear of the car? This one just seems most satisfying because you can see it too.
TIA, Nick.
MARO-MAN, I would personally get the TDS wonderbar before the stb. It's only 50-something bucks, and rumor has it, it does more for your car. Think of it as an under-the car STB. I have one, and will be installing it as soon as my BMR STB arrives.
Old Dec 18, 2006 | 08:22 PM
  #55
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
TIA, Nick.
Anybody I just want to know what the install all takes?
Old Dec 19, 2006 | 07:49 AM
  #56
wgripp's Avatar
I think you just need to drill a few holes and install a few bolts.
I dont know about about the firewall lip.
Like I said, I'd get a TDS wonderbar before an STB.
Old Dec 19, 2006 | 09:50 AM
  #57
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Yes, but end up with both.
Old Dec 19, 2006 | 11:22 AM
  #58
wgripp's Avatar
But, if you are on a budget, get the wonderbar first.
Old Dec 19, 2006 | 04:53 PM
  #59
MARO-MAN's Avatar
Thanks wgripp TDS Wonderbar? I have only seen the Spohn wonderbar. Anyone have a link to one. TIA, Nick.
Old Dec 19, 2006 | 05:18 PM
  #60
wgripp's Avatar
http://www.top-downsolutions.com/pro...products_id=45
Old Dec 20, 2006 | 11:10 AM
  #61
MARO-MAN's Avatar
Finally, a suspension product that meets my budget and sounds like I will actually feel a difference. Thanks, Nick.
Old Dec 20, 2006 | 11:21 AM
  #62
wgripp's Avatar
No Problem!
Old Dec 26, 2006 | 01:44 AM
  #63
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Originally Posted by Cam-aro
I have a Hotchkis Brace... but lemme tell ya something, it doesn't have proper clearance with a Holley Stealth Ram Intake... I get vibrations through the hood.
How did you get that 2pt. brace over the HSR? Did you have to space it up? If installed 'normally' the brace hitting the hood wouldn't be an HSR problem unless it hits the HSR as well. This has been discussed many times and the ultimate answer always came back nothing will fit. If it will fit thats sweet because I desperatly want one back! My HSR pretty much hits my hood as it sits now.
As far as STB's go I had a Kenny Brown 3 pt. and loved it. 3 pts. are better than two and both the Kenny Brown and BMR are awesome and look great. The Edelbrock piece is nice too and if I had a carb or TBI car I'd get it.
The wonderbar is a must for these cars.
Old Mar 3, 2007 | 11:08 PM
  #64
rmmstnr's Avatar
Car: 89 TA
Engine: 305 TBI
Axle/Gears: 10 bolt 3.08
I wonder if a Weiand 144 Low Profile blower wit sit under one of Edelbrock STB's? I've looked at pics of both and it looks close from what I've seen, although probably an inch or two in the way...
Old Mar 3, 2007 | 11:53 PM
  #65
chevylover5's Avatar
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
wtf, im a decent welder, do you guys think i could just make one out of sum round bar?
just measure it out, center it notch it and weld a solid 3 piece
think it could be done?
Old Mar 4, 2007 | 12:30 AM
  #66
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
If you have a welder pretty much anything can be done
Old Mar 4, 2007 | 12:53 AM
  #67
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Before i went back to the stock aluminum intake I had a ZZ4 intake.Its about as tall as the edelbrock unit for these carbed models.Anyway the edelbrock STB would fit but not the 2 bars for the 3 point set-up.I would think the weiand blower would present the same dilemma(if not worse).Also if you dont have the fiberglass hood the strut may contact the hood!I had to adjust my STB to its highest(almost)setting to clear the Z4 intake & it came close to hitting the hood afterward.
Old Mar 4, 2007 | 01:42 PM
  #68
wgripp's Avatar
Maybe his motor mounts are a little worn, and the engine has sagged a bit?
Old Mar 22, 2007 | 05:29 PM
  #69
wgripp's Avatar
Re: Strut Tower Brace
Will the TBI version of the edelbrock fit a carb'd car with an aftermarket carb and lifter plates? My friend wants to get one.
Thanks!
Bill
Old Mar 22, 2007 | 06:48 PM
  #70
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks!
Bill
The edelbrock brace goes aroung the front of the aircleaner.Instead of over it.Depending on what air cleaner,carb,spacers your using.Its hard to say itll work with his pplication.
Old Mar 22, 2007 | 07:14 PM
  #71
wgripp's Avatar
Do they make a carb friendly STB at all?
Thanks,
Bill
Old Mar 22, 2007 | 07:20 PM
  #72
Stephen's Avatar
Car: 87 GTA
ABSOLUTELY!!! Same goes for SFCs. I can't see spending $200 on $30 worth of tubing, flat steel, and some nuts & bolts. You can build a wonder bar yourself too.
I like the KB one. No flexing at the mounting points. More secure. That's how I planned on building mine, just never knew any aftermarket ones had been built that way.
Build a wonder bar first. You will notice those immediately, whereas the STB is something you you will only sorta notice, in HARD corners.
Old Mar 22, 2007 | 07:45 PM
  #73
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
I don't see it in their site, so they must not have sold too many. Is it welded in or a bolt on?
Old Apr 4, 2007 | 05:30 PM
  #74
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Here is a MAC performace products STB chrome. The bolt holes on mine didn't fit so I had to drill them out. Other than that it's not expensive(90) and it tightened up the front noticeably. It bolts on to the factory strut bolts. I got it from FASTTOYS.NET.
Attached Thumbnails Strut Tower Brace-im000349.jpg   Strut Tower Brace-im000350.jpg
Old Apr 7, 2007 | 12:01 AM
  #75
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Originally Posted by Jekyll & Hyde
Personally, I like the hotchkis the best.
I noticed a huge difference in handling. It also killed the strut popping when pulling into driveways or going caddy-corner into parking lots, etc.
Wow...as a previous poster said, I had no idea what that was...it drives me nuts. Only happens when I turn the wheel to the right to full lock though, either going into or backing out of a parking space. I've got a TDS wonderbar and it didn't do a thing for it. How serious of a problem is this?
Which one of these would fit a carbed 305 (84 T/A with stock carbed 305) the best? I really like the look of the edelbrock but what's the difference between the ones that are hinged and the ones that bolt right to the strut tower?
Old Apr 7, 2007 | 12:08 AM
  #76
Stephen's Avatar
Car: 87 GTA
AFAIK, only Edelbrock makes one that will fit the carb'd or TBI'd cars. It it a 3 pt, and has the bends in the cross-bar, to fit in front of the air cleaner.
Jeg's
Part #350-5227
Old Apr 7, 2007 | 08:57 AM
  #77
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Hey, would you mind taking a measurement of that for me? I need to know on the driver side how far the bar is from the ground. I'm trying to find out if this will hit the A/C compressor on my V6 or not.
Do you have aftermarket wheels and tires on your car?
Old Apr 7, 2007 | 12:18 PM
  #78
Ozz1967's Avatar
Car: 1984 Trans Am
Nope, factory 15's.
Old Apr 23, 2007 | 12:26 PM
  #79
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
i just installed a 3 point on my car tbi along with a new thq arm and the car is totaly differant. its night and day. Im happy with the results. im hopping ill gain some more when i install my rear hotchkis set up and subframe connectors.
Old Apr 23, 2007 | 12:50 PM
  #80
Stephen's Avatar
Car: 87 GTA
Get a Wonderbar. They make a more noticeable difference than the STB. Not to mention, a LOT cheaper!
Old Apr 23, 2007 | 02:53 PM
  #81
Ozz1967's Avatar
Car: 1984 Trans Am
I put a wonderbar in and to be honest, the only difference i have noticed is it doesn't roll as much around corners anymore. And it's not that much of a difference in my opinion. It did something though...and for $50.00...I suppose it was worth it. Now to get the strut popping to stop...that's what I need to try and do.
Old Apr 23, 2007 | 03:19 PM
  #82
DerrickB4C's Avatar
Car: 1991 CAMARO RS
im going to get a wonderbar when i replace my sways. my car seems to ride better than it did even on crapy michigan roads. there are a lot of things im still looking to change on the suspention to make it a enjoyable car to drive.
Old May 8, 2012 | 06:28 PM
  #83
ravagebang's Avatar
Car: 1992 Camaro RS - medium quasar blue
Engine: 5.0 l. 305 cid. TBI L03 VIN E
Transmission: TH-700R4
Axle/Gears: 10 bolts 28 splines 7.625" 3.23
Does Edelbrock Strut tower brace fit with offset base of open element air cleaner?
Old May 8, 2012 | 08:43 PM
  #84
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
I have the Edelbrock as well, sorry no photo.
Old May 8, 2012 | 08:53 PM
  #85
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what do you mean? a drop base air cleaner, or the ones that aff offset 1.5" to move the aircleaner to the center of the car? Either way, yes. I had the offset cleaner for years with no issues with the edelbrock STB for carb/tbi cars
Old May 9, 2012 | 10:34 AM
  #86
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Did anybody ever come out with a proper fitting brace to fit the HSR?
Old May 10, 2012 | 07:00 AM
  #87
ravagebang's Avatar
This is Offset Drop Base Plate:
http://www.pickupandracehaven.com/me...095-detail.jpg
This is Offset Flat Base Plate:
http://www.knfilters.com/images/85-3540.jpg
Both offset bases moves the aircleaner to the front of the engine to avoid contact with HEI distribuitor. But wich one fit better, drop or flat?
Thanks...!
Old May 10, 2012 | 07:24 AM
  #88
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm using a drop base with no issues. Check my vbGarage (shedlike icon next to my online status on the left) for a pic.
JamesC
Old May 11, 2012 | 04:25 PM
  #89
defaced's Avatar
Car: 1987 Firebird Formula
Engine: 355
Axle/Gears: Posi, 3.23
There's my BMR brace. Honestly, I can't tell any difference. I guess I can say that my steering is a little tighter. Got mine from Summit for about $110.
EDIT: Can anybody see my picture? I posted it from my phone and it's just a red x on my work computer and doesn't even show up on the phone. lol
Old Jun 28, 2013 | 09:38 PM
  #90
gbettner's Avatar
From: Close to Boggstown Indiana ( out in the middle of a corn field)
Car: 89 Iroc, saved from scrapyard
Engine: 350 vortec w/stealth ram
Transmission: 85 corvette 700r4
Axle/Gears: 3.73 posi
I have an eldebrock STB just like the one in above pics by member "Cadillac". It came with the IROC I bought which was originally a TBI but I installed a 350 TPI and it hits the throttle body. Anyone ever modify a TBI brace to fit TPI? I was thinking about cutting out a 12" section of the brace in the middle and replace with 12" of 1/2"x2" flat plate flush with the top of the tube. I don't know how much wiggle room there is on clearance.
Is there a TPI version of that particular Eldebrock brace that anyone knows of? If so does anybody have pics they could post?
Old Jun 30, 2013 | 04:46 PM
  #91
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Thanks...!
I've been needing one of these to center my air breather into my good mark cowl hood.
Old Jul 23, 2014 | 02:56 AM
  #92
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
Founder's seriously needs to make one of these….
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
