Color Sanding cost $$$ question
Old Jul 27, 2006 | 09:30 PM
Zink57's Avatar
Car: 1987 IROC Z
Engine: LB9
Transmission: 700-4R
I was wondering how much it would cost to have a 3rd gen color sanded. I was told that my paint was a bit faded and would benefit form color sanding.
Any ideas of the cost, labor involved at a professional.
Old Jul 27, 2006 | 09:42 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
just have car wax
wet sanding is not really good, they might burn the clear.
Old Jul 27, 2006 | 10:11 PM
boredomkills's Avatar
Car: 1992 rs
Engine: 350 tbi
Faded paint is better to go at with a ruffer buffing compound by a proffesoina(easy to burn through paint)l or if you have at least a little idea of what you are doing just use a less agressive compound and just work on it longer. Be careful if you car is one of the years with the paint that peels easily.
Old Jul 28, 2006 | 06:51 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
If it's the stock paint, don't sand it. It's way too thin for that. If it's a newer paint job with 3 or 4 coats of clear, then search the boards and find out how to color sand yourself and save a few bucks.
Old Jul 28, 2006 | 09:42 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
if you go through with it, have a body shop do it. Sanding and buffing is definently an art...it's very easy to screw up an entire paint job. If your paint is faded (depends how bad) chances are you can just use some compounds to intensify the shine without having to sand the car.
Old Jul 28, 2006 | 10:13 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Like mentioned above if its a factory clear coat id probably go with some meguiars diamond cut compound, then some meguiars #9 swirl remover and then wax it back up.
If its got a few coats of clear on it (not factory) id wet sand it with some 2000 grit paper. Then apply the diamond cut and swirl remover followed by some wax.
69 Six Pack
Oct 5, 2015 07:51 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
