Z28 ground effects on an 86 trans am
Car: 86' Trans-Am (wrecked)
Engine: none currently
Transmission: Borg-Warner T-5
Axle/Gears: 2.86:1 w/ one broken axle
I have been looking at pictures on here and I have noticed that the Z28s have sweet ground effects on the sides. The bottom of the front fenders and underneath the door. I am just curious if this would mount on an 86' Trans Am or would it even be worth trying? Just wondering.
Engine: Cammed 6.0L LSX
85-90 trans am ground effects go further up than 91-92 camaro ground efx. The trans am ground effect that attaches directly to the door is twice as tall. The 1984 trans am front and rear ground efx would match better with 91-92 side ground efx.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I actually like it. Flows pretty well and goes with the front bumper pretty nicely. Looks like it was meant for the car.
Redraif has them too, but not with 85-90 trans am ground effects but 84. www.redraif.com
Car: 1987 GTA
Transmission: 4L60e
Personally - in order to do this "mod" right, you'd have to have the 84 TA style Ground FX just because the level of the front gfx doesn't match the center if you use 85+.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Car: 89 f-bird and some others
Engine: 3.4
I thought about doing this too. There's a set at the junkyard right now, but the right side door piece is missing.
Saw a GTA or formula spoiler too (not sure which), but one side is warped a little, and I'm not sure how hard they are to straighten. (rubber like stuff)
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
92firebirdchris
Aug 14, 2015 11:56 AM
