Best way to remove paint
Car: 87 camaro z28
Engine: 2.8l V-6
Transmission: TH-700R4
I need help I got tinted windows and a friend took some kraylon primer spray paint and sprayed it on my door and some of the overspray got on the window what is the best way to remove the paint from the window.I tried the water and razor blade but it does not seem to be working well so what is the best way to take the paint specs off the window
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
If its on the outside of the window, try some thinner on it and then go over it with window cleaner and 000 steel wool. If its on the inside of the window im not sure theres much you can do without hurting the tint.
Matt
Matt
NBrehm
Aug 25, 2015 11:49 PM
