REAR LENS TINT
REAR LENS TINT
Like the look of blacked out rear lens and want to do mine. What is the spray everyone is using. I like them blacked out. Tell me how you did it and pics. Thanks.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: REAR LENS TINT
you can use nightshades or you can mix some clear, and black together, and spray them with spray gun thats what im gonna do when i pick up another set of grids
Re: REAR LENS TINT
The vht niteshades I ordered from o'reillys made my front side turn signals light up red. I had them blacked out to the max, as black as the black paint on my car. I think there is some red dye in the paint or something. I'm going to try testors tint paint next.
Car: 1991 Firebird
Engine: 3.1L V6
Re: REAR LENS TINT
Firebat, did you spray clearcoat on there also? Or just buff the vht, I heard it makes it looks kinda flat rather than glossy. Also i'm sure you sanded before spraying, what grit did you wet sand with?
Re: REAR LENS TINT
From what I've read on the net about vht niteshade is that you want to wetsand the plastic down to 400, then 800, then 1000 grit. People have had problem with 1500 grit or higher. After you wetsand the plastic to 1000 grit, clean it with dishsoap and water. Dry it off, wait a little bit, then apply the paint.
After the vht is sprayed on, let it sit for a few hours. Then wetsand it at 1000 grit. Then apply clearcoat and buff the clearcoat.
hectre13
Dec 11, 2023 08:14 AM
colton_carlson
Mar 8, 2019 12:21 PM
Polo Z03
Sep 10, 2015 06:43 PM
