Factory 5 spokes
Old Aug 10, 2007 | 05:01 PM
fireeagle43's Avatar
Factory 5 spokes
I have a set of factory 5 spokes, the type that came on early Z/28s and later RS's and they have what appear to be brake dust embedded in them.
What would be a good way to clean them and possibly polish them? I also have a pair of factory 16" rims that look the same, are they made out of the same material? And could they be cleaned the same way?
Old Aug 10, 2007 | 10:01 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Factory 5 spokes
They are made of similar material,both aluminum,with painted accents then clear coated.The clear coat has a tendency to peel after years depending on weather and type of cleanings.Make sure the cleaner you use is for clear coated/painted aluminum wheels(I use Meguiars All Wheel cleaner for a long time).You can use a brush(medium bristle - not stiff)for cleaning the wheels.Then you can use Meguiars,or Mother's,wheel polish after they are clean.
My '83 came with the 15" 5 spoke gold accented aluminum wheels but I've changed to the 16" IROC single stripe('85-'87 style)gold accent wheels on her.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
