How would this look?
Old May 10, 2001 | 09:12 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
How do you guys think these ground effects would look combined with a RamAir hood? I'm talking the LT-1 style ram air, not the '98 and newer style.
This doesn't look ***** does it?!?!
Old May 11, 2001 | 12:21 AM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I like the Ram Air hood...but i dont like those gfx at all...seen them before...look cheesey and low quality to me. Just my $.02.
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old May 15, 2001 | 09:07 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Anyone else? Maybe someone knows where I can find the stock '84 Trans Am ground effects in good condition for not alot of cash?
[This message has been edited by AT4 T/A (edited May 15, 2001).]
Old May 15, 2001 | 09:28 PM
Chaotic Firehawk's Avatar
Here's a Formula with ram air and those gfx, looks mean as heck RCR,hope you don't mind me using your car
https://www.thirdgen.org/rides/index...ew&rideid=1117
Car: 1989 Firebird Formula with T-Tops
UBB Member: RCR
Cylinders: 8
Displacement: 350 cubic inches
Transmission: Automatic
Rear Gear Ratio: 3.73
Horsepower: 247
Torque: 315
Top Speed: 135 mph
GM CC 350 Crate Engine (factory rated @ 300hp)
LT4 Hot Cam
Converted TBI to '88 TPI wt Major porting
Accel DFM system wt Calmap Software
SLP Runners (ported)
TFS Twisted Wedge aluminum heads
Powder Coted Edelbrock TES Headers
Crane Gold 1.5 Roller Rockers
Pro-Built 700R4 Transmission
Vigilante 2700 RPM Stall Torque Convertor
'84 10 Bolt Series 3 Rear Axle with Disk Brakes
Axle and Hardware Powder Coted Black
Auburn Posi
GM Motive 3.73 Gears
Aluminum Drive Shaft
GTA-style black mesh wheels with WS6 center caps
BF Goodrich CompTA A/B tires 255/50R16
IRS Tubular Subframe Connectors
IRS Tubular LCA's and Panhard Rod
Koni Adjustable Hydraulic Struts
Rebuilt front-end wt all Energy Suspension parts
http://members.home.net/rcrabine/rcrhomepage1.htm
Chaotic Firehawk can be found wondering NEThirdgen.org and 3rdgen.org
"A musclecar, by definition, is a powerful and sporty vehicle that must be able to spin its tires at will. The Firebird Trans Am is capable of laying down twin black streaks of rubber several hundred feet long. We wanted to be sure it could, so we did it a half dozen times in the name of automotive science."-MotorTrend
