92 Z28 scoops on a 92 RS hood?
Old Dec 10, 2007 | 05:17 PM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Transmission: TH700R4
Hello
Can I put 91-92 Z28 stock hood scoops on a 92 RS hood?
Is there a difference between a 92 RS hood and a 92 Z28 hood?
Cause a friend can sell me a set of hood scoops from a 92 Z28 but I don't know if I can put them on my RS hood.
Thanks for your help
Old Dec 11, 2007 | 01:04 AM
85S10projectz28's Avatar
Car: 91RS, 90 K5 Blazer
Engine: 91 355 TBI
Transmission: 91 700r4 with shift kit
Re: 92 Z28 scoops on a 92 RS hood?
Originally Posted by wahoo
Hello
You will need his hood to install them on your RS. Otherwise they will just be bolted up on top of your hood and look like crap.
Old Dec 11, 2007 | 01:27 AM
Red1992V6Rs's Avatar
Car: 1992 RS
Engine: 3.1
The hood blisters (scoops) will not directly fit onto an RS hood. You will need a 85-90 z28/Iroc-Z or 91-92 Z28 hood.
Edit: I just saw your in France. That's awesome. I'm sure there aren't too many thirdgens over there.
Old Dec 11, 2007 | 04:14 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
the z28 hoods have indents in them for the blisters to fit into, your rs hood doesn't have any holes for the mounting bolts either (if they're bolted in, they may be clip in, I dunno Im a Firebird guy)
Old Dec 11, 2007 | 06:20 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
They are bolted in with a speed nut....I have an 87 with 92 blisters....
Old Dec 11, 2007 | 06:23 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
HawkThirdGenParts.com sells the blisters that are made to fit on the flat hood...
http://www.hawksthirdgenparts.com/in...ROD&ProdID=129
They go for $130 a pair, and you would need to drill holes in your flat hood, along with some prep work to get them to work.
Good luck!
-Tim-
Hotrodboba400
Dec 10, 2019 07:07 PM
86Firebird86
Dec 26, 2015 07:21 AM
Ranbo108
Sep 9, 2015 12:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
