Broom Scratches on White Body!
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Hey guys,
I think I ruined my car's paint. I kept it outside and in the morning I would use a broom to wipe off all the snow. I've washed this car numerous times and I can't get the brown bristle marks off. When the car is dry I can scratch them off with my nail so it seems to be some super hard dirt. I've been using ICE Car wash. Should I be using claybar? What is it and will it get rid of these ugly brown patches on my car? Do you recommend any good ones? I really screwed up.
-Peace
-Peace
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Broom Scratches on White Body!
Yeah, thats almost as bad as me using a porcelin coffee mug to scape ice off of my windshield.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
first try some bug and tar remover , you may be suprised . i was . then a good wash and polish/cleaner . do the simple/easy stuff first . hopefully its not as bad as you think . good luck .
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
yea i dont see it being to deep from a straw broom if the other stuff mentioned above doesnt work like the clay bar and stuff you could get a buffer and some compound and polish and go to work.
Car: 1987 IROC-Z
Transmission: 700R Auto
Just use good old WD-40 and you will be happy again.
After you use it to get the crap off your paint you will need to put a good coat of wax on her.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I agree with GOOMAN. Do the simple stuff first and try to disolve the broom marks with WD-40, or adhesive remover, or just soap and water with a microfiber rag. Then spot polish and wax. My experience says a clay bar will take a long time and a bunch of elbow grease if it even works at all on this. You need something to disolve the residue and not mar the paint.
morrow
Jan 13, 2024 12:29 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
